Ricoh aficio mp 2851 user auth error / no privilegies as admin help request
  • zzluis12
    • May 2019
    • 6
    Hello guys, my name is Luis, im an IT guy, many years of experiences, but not that good at printers / copiers... So i hope you can help me with this one and guide me in the right direction.
    I got a call from a friend who started a Library thing, so he has a Ricoh MP2851, he wanted to share his Ricoh into network, so other computers can access to it, and be able to print, and scan. So i did. plug some cables, install drivers, configure them in Network, not a big deal, something im used to... but here comes the complicated thing;
    I can scan, and print from the computers in the networks, but that friend of mine told me that, sometimes he needs to scan a whole entire book, and doesn't want to put book in the scanner, go to computer, scan, go back, flip the book page, go to computer, scan... and that repeatly thing.
    I just configured the printer / scan in his computers S.O (Windows) itself. Didn't touch any of the copier configuration, which is an area that im really used to do, but as an IT its easy to me to understand these or any kind of systems...
    So i did, i went throught the menu, set an ip address, a shared folder in network, he has a domain and hosting, so i were able to configure the SMPT, test the conections, ping command, and everything seems to work fine... BUT when i tried to Scan, pressing the button in the copier, and then Start, It does NOTHING. which is where i didn't knew what to do.
    He bought it used from a guy, so it had preview config and stuffs, he only had access to User auth from the previous owner, not admin/supervisor auth... So as someone who knows about systems, i read some stuffs online, mostly here, and figured out, that i had to grand privilegies, to the user, who claims that he never managed the Scan thing from copier to work correctly (from the copier interface), but he did it, scanned throught computer directly, using a digitalizing software.
    I tried to access to the admin thing. admin/blank, and it says password was wrong, i asked if he do know something about the admin credentials, he said nope, so reading things here, i was able to reset the admin password from SP
    Originally posted by terramobil
    To delete all customer Data, execute
    Fax SP 5101 and 5104 and
    System SP 5801-004 to 5801-021, 5816-209 (@remote data), 5832-001 (HDD Clear), 5853-001 (stamp data), also in
    Spezial SP (Login with143) 5846-046 (Admin passwords)
    This procedure will not reset counters, registration data etc.To delete all customer Data, execute
    So i reset the admin password. or that i think thats what i did, to be honest.
    Reboot the copier, turned on, and prompts thad i had no privilegies (as starter user) to use copy functions, scan, any other thing, etc.
    So, back from the start, i knew that i had to create a user and grant him privilegies, which i couldn't do before, because i had no access to admin user.
    Logged in as admin/blank, worked now, i created a new user in the booking address, put his auth login info, admin2/blank, because i was testing and stuff, it seems to save, created correctly, but when i try to log-in as that new user that i just made, it says the User Auth failed? because of a wrong password?
    So i went throught the web magnament thing, the user was there, tried to change his login details from the web magnament instead of the copier itself, and still nothing, whenever i tried to login, it says Auth Failed, after getting into a dead end, logged as admin, i disabled the user auth stuff. The log-in button thing in the display of the copier dissapeared, and Right now, i am able to access to the Scan UI thing, when i press the Scanner Button in the copier.
    But when i hit the Start button, it does nothing, so i dont know what to do, as i need the scan thing to work out, in order to set the destination of how to send these folders, in any mean, being SMB, or SMPT (from the hosting he has) like to scan a whole book in the copier itself, and dont be like go to pc, scan, flip book page, go to pc scan... and repeat SO...
    I told him, that in what my knowledge concerns, the failure must be some kind of bad configuration from the previous owner, maybe disabled the Scan thing via SP Service menu, that maybe replacing the SD card thing could fix it / maybe a ROM update could fix it (i wanted to try that Firmware thing, but didn't found any)
    What do i do? As an intending to help that friend of mine with his library thing, i ended like a tech that doesn't know what to do, but w/e, you learn everything new everyday, and thats why i am here, hoping that some experts in the area point me into the right direction, and suggest me how to fix that, maybe someone experienced something like that, idk, but i'll be glad to hear you out.
    Thank you so much for taking the time to read this,
    Hoping that someone can help me out with this
    Cheers.
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh aficio mp 2851 user auth error / no privilegies as admin help request
    If I am understanding you correctly, just use the document server on the machine. It will scan and store files onto the copier HDD for printing access anytime you want.
    NEVER ASSUME ANYTHING
    • COPIERMAN
      • Jun 2009
      • 559
      when you press scanner button make sure folder tab is selected on display and it will show any user that has been setup in address book. then select user and then start. to let you know that on computer need to create a local user then make a share folder on c;drive and make sure that local user show up in sharing and security tab and have full permission. then on copier go through web monitor using ip address of copier log in default is user admin and password is blank. then look for address book. click on add user then scroll down to folder autho. enter user and password then scroll down to folder and in path enter scan folder path. if you search on this website you can find better instructions on setting up a scan folder. One note this copier uses smb1 protocol unless it had a firmware upgrade to use smb2/3.
      • zzluis12
        • May 2019
        • 6
        Yes, i tried that, and it does work when it comes to print a digitalized thing* But still need to be able to share it by anymeans to get it in a PC, to keep it, as most people, scan a whole book, and want it as PDF... As there is no option to send the files from HDD Copier to the PC, that wont work for me... At least i didn't find any option like that, from Document server. If so, is possible to access to Document Server from PC / Web thing?
        It wont allow me to select a folder or any item while in there, I did shared a folder throught network, set them privilegies (at windows, allowing read/write permissions on the folder) But the thing is, that after i add a user into the address book, and granted that user authorization for scanner/all functions, etc. I try to login, and it says password its incorrect...
        I mean, i made (in address book) like anyuser:blankpassword.
        When i try to login in anyuser:blankpassword, it says its wrong, and wont allow me to login in the copier itself.
        I saw a video today about a guy entering in the System SP Thing, and he pressed like a button to log-in as developer, haven't tried that because i dont know if that will grant me like permissions as developer, in the video the guy just select the option and thats all, doesn't explain anything.
        This is the youtube video that i saw with that developer, but i dont know if that will do something about
        YouTube
        The thing its basically that whenever i create a user, when i try to login, it says the login information its incorrect, while i set up all, but still says like its invalid.
          • 37484
          That last version of Windows OS that I know of which supported scanning without a password was Windows 98.
          • davel
            • Oct 2011
            • 1104
            Sounds like you have no idea what the machine can do, press scan - store then go to pc browse the machine go to document server, select file and download. Do no t use document server button.
              • 37484
              Too bad that Scan to memory device was not introduced until the MP 2852 because that is exactly what your friend needs.
              Has your "friend" contacted an attorney to determine the legal aspects of copying the entire contents of a book to electronic media. The book publisher(s) just might take legal action to stop you.
              • 8T2
                • Aug 2015
                • 257
                Ok let me be the first to complain about you messing around in service mode.
                You really should not mess around in service mode if you are not a trained tech. The developer initial setting for instance has nothing to do with developer (software God mode) and everything to do with a physical part in the machine.
                So far it appears that you haven't cleared anything important yet but I assume the next step when clearing user data etc unsuccessfully is to just quickly try a full memory clear.
                Log a call and get a tech out if you run into issues, how would you feel if your friend at the library calls you saying his PC stopped working because he had a issue logging in and after watching YouTube vids and checking forums he messed around in powershell and regedit. It's the same thing.
                Now with that off my chest I would recommend installing the twain driver (available from ricoh-support website) for that specific model and using a program like scanwiz or whatever you like to do scanning in the meantime till you can get scan sorted out on the device.
                You're description of the exact problem with the scanner is a bit unclear. When you say you hit scan but nothing happens do you mean the scanner function does not start up at all? Or it does start up, you select the scan destination hit start button and nothing happens, or hit start it scans the document but comes up with an error/failure?
                *EDIT* After my rant I could focus beter and read OP again and you say you can access scan feature but nothing happens when you hit start.
                Silly question but does the destination the folder you created for scanning show up on scanning screen? Destination has to be selected because there is no single default scan setting on these devices. And as someone else mentioned earlier if it is not showing the destination as an option make sure you are in the correct tab (folder or email)
                  • 37484
                  Did you actually read the third paragraph of his original post??
                  • zzluis12
                    • May 2019
                    • 6
                    Yes i know, what i mean, not it windows, but in the copier itself, when you create a in the copier book address. I do make a new user, but when i try to login, it says user/password its wrong, even after i made one like 5sec before.
                    It ONLY allows me to login as admin using a blank password. Which is the one who comes by factory.
                    As Admin, when i login, it prompts that i dont have privilegies to scan/copy or most of the functions, thats when i was trying to create a new user, different than admin, where after i add permissions, i need to test out if it works. The point its that it wont allow me to log me in by anything than Admin.
                    To be honest i really didnt knew what machine can do. My service finished after all the computers in his network were able to print and scan, sharing them in windows and stuffs, not a big task, Now when it comes to the copier, which is not really my area, as a IT, i got an idea of they should work, so after reading stuffs, and documenting myself about it, it has the function to save the files in the computer, or sending via email using SMPT.
                    But, as i said, when i go to the Scan inteface (after pressing the Scan button on machine) and pressing START button in order to the copier start the scan, it does nothing. I can not select FTP, SMPT, or shared folder options, config thing, it doesnt allow me to do that, because i lack of permissions as Admin User.
                    Thats the reason because i created a user, and grant that user permissions to edit that config, setting it up in address book.
                    But after creating a user, IT DOES NOT ALLOW ME TO LOG-IN IN ANYTHING THAN ADMIN, IT SAYS USER/PASSWORD ITS WRONG.
                    So basically my problem is, WHY it wont allow me to log in in a user i created in address book. Says like its wrong, but i created and configured it correctly.
                    As far he told me, its mainly for guides for university students, and these kind of book-guides that they use at they school or thing, honestly i dont know if he had cases like with a books with copyrights that can put him in a trouble... As a frustrated tech right now i just want his copier to work correctly, and as a professional, i suggested him indeed, that he can get in troubles if he start to copy and distribute these things without the book publisher concerns, or anything that its copyrighted. But its really all up to him.
                    he is a friend of mine, but he is paying me for the service, which was installing drivers, configuring, sharing the printers and the copier, to make them work correctly in network with the computers he has. My service as a IT was completed, because it was a Windows thing. Now when it comes to the copier, its an additional thing that i dont know how to do it, because its some kind of messy config with it. thats why i am here, because its not really my area when it comes to hellycopiers
                    It does not allow me to select in the copier interface the destination from where i want it to be stored, being these methods, shared folder in computer, or SMPT. When i press the start button, nothing happens. And i cant configured them, because i lack of permissions (as admin user) to do it. When i try to login with any other user that i just made it says its wrong auth, like if the password were wrong or something...
                    • skinnyb
                      • Jul 2008
                      • 291
                      Sounds like your friend needs to contract a knowledgeable Ricoh technician to come and help sort this out. Scanning with devices is not that difficult unless you are not familiar with the correct operation. Just reading your descriptions of what is going on makes no sense and makes my head hurt. Good advice was given me years ago, stay in your lane Maybe when the tech comes out, stick around and learn something new and useful for the future.
                      Sent from my LM-V405 using Tapatalk
                      • zzluis12
                        • May 2019
                        • 6
                        Yeah I'll tell him to do that, I tried here to see if, with the help of the community, I could figure something out as far as I can. Since I don't, I'll tell him let someone in his area to take a look. Otherwise if someone want to aport a solution or experience about it, it will be useful for me in the future. Because I am in a new country nowadays and here, these kind of things, copiers and stuffs, it's something that I can do too.
                          • 37484
                          First off admin and supervisor login is for accessing items in the User Tools and WIM only. They do not have permission the use any function.
                          User names in the address book are for setting fax numbers, scan to email accounts and scan to folder users. They are also used in conjunction with User Authentication to allow users (not administrators) access machine functions that are setup in User Authentication as requiring login. The login screen for those functions will appear when you select one of those function. It is also used to restrict print function to those who have an authorized User ID entered in their print driver. Through the address book you can also set things for each user such as their fax number, email address and path for scan to folder. For scan to folder you can specify whether to use the default user name/password or to enter one in the address.
                          • zzluis12
                            • May 2019
                            • 6
                            I had a very basic idea of all these things who you just described, but now i know how they exactly work, thats a good detailed thing you wrote there, its helpful, as i said, i'm looking to expand my knowledge as well, so i can do like multi-tasking as an former IT Tech.
                            So knowing that As admin user, I DO KNOW I CAN, AS ADMIN ONLY access and modify the User Tools, ithats the admin user functions, as you just described, to manage, modify, and set up any kind of configuration to USERS and ANYTHING ADDRESS BOOK RELATED,
                            and I do know, as ADMIN that I CANT access to copier functions unless i had previously set it up all from User Tools.
                            BUT. The main thing is that AFTER I CREATE A NEW USER (FROM ADMIN).
                            It wont allow me to log in, with that user i just created.
                            Example:
                            I go to User tools, make a new user, code 0002 with the following parameters:
                            User name set to slimslob, code 0002
                            Grand him permissions to Copier functions; All of them. Copy, Document Server, Scan. All of them.
                            Set it up the Path of Shared folder, to the folder located in \\PC01\SCAN to slimslob, user code 0002.
                            Set the User Authentication LOGIN to slimslob.
                            Set the User Authentication PASSWORD to 123
                            SAVE all the config i just made.
                            But When I try to login as slimslob, using Login:slimbslob password:123
                            It says that the ENTERED LOGIN/PASSWORD its INCORRECT, and WONT LET ME LOGIN.
                            NO matter how many users i create. No matter how many passwords combinations i set. WONT LET ME LOGIN
                            I CAN ONLY LOGIN AS ADMIN / SUPERVISOR
                            And thats the main problem. I've configured everything, But i cant access as user.ll Tomorrow i'll make some time and go to my friend's place to see if i can record you some videos and show you guys exactly what i mean.
                            Because after testing all the things as far i can. IT still WONT LET ME LOGIN
                            By that, I can only asume that:
                            its because of corrupted ROM?
                            Its because a bad manipulation of SP menu thing?
                            Its because it needs a Firmware update?
                            I assume these things because it was bought USED. So I can only think that, the previous owner, put it on some messy configuration.
                            EDIT:
                            I DONT COMPLAIN ABOUT TELLING HIM TO HIRE SOMEONE ELSE TO DO THAT WORK.
                            I TOLD HIM ALREADY, THAT HE MUST LOOK FOR A EXPERIENCED GUY IN THAT AREA, WHICH I AM NOT.
                            BUT
                            I STILL WANT TO LEARN ABOUT IT, AND SEE WHY THAT HAPPENS, AND HOW TO FIX IT. BECAUSE AS I TOLD, I AM LOOKING TO EXPAND MY KNOWLEDGE.
                            • davel
                              • Oct 2011
                              • 1104
                              The user name and password you enter after setting folder must be the name and password for the computer the folder is on, not just a random one you make up. If the computer does not need a login it will not work.
