SPC360SFNW sc 332-01/02&03 continue
  • jsr123
    • Sep 2012
    • 11
    [Error Code] SPC360SFNW sc 332-01/02&03 continue
    Dear All
    Four new SPC 360SF error code sc 332-01/02/03 continue.
    Replace with new toner still after few prints error return.
    One machine stuck with sc 332-03 add yellow toner.
    No blockage at developer entrance. Toner no issue ok.
    Will this need f/w update. What are other solutions.
    Re: SPC360SFNW sc 332-01/02&03 continue
    Originally posted by jsr123
    Dear All Four new SPC 360SF error code sc 332-01/02/03 continue.
    Will this need f/w update. What are other solutions. Thanks
    Dear Newbie,
    You need to give more info:
    did you replace drums/devs?
    what is total count on machine?
    what is the count om PM parts?
    Are you a tech?
    do you have service manual?
    other than toner WHAT haa been done to it?
    Phil B. "The Dentist"
    • davel
      • Oct 2011
      • 1109
      If they are all new machines send them back under warranty, did you miss a step in the run up procedure, if not new call a experienced tech.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Four faulty machines at run up?...methinks you need to double check the run up guide..!!!
          Me thinks You are correct!
          Unless they are " refurbs" some shady dealers out there..
          But yes.. most likely, incorrect setup.
          • kannuki2
            • Feb 2012
            • 398
            This SPC360SF is a POS. So, the machine was installed about a month ago. Today, It throwing sc332-01 after 10 or 5 pages print and the code can be reset by power off and on. I output check development motor drive the Blk pcdu good, and replaced two new black toner cartridges. Also, I swapped K toner clutch with a Magenta clutch and still no fix. Any ideas would greatly appreciated.
            Machine counter page info
            Total Black counter = 207
            Color= 153
              • 37652
              Color= 153
              Start a new thread.
                Color= 153
                different issue start your own new thread
