Ricoh mp c5503
  • heath03
    • Jul 2018
    • 80
    Ricoh mp c5503
    riicoh paper tray not changing with different size paper?
    for example its loaded with 8.5x11 but it stays on 12x18
    I've tried to refresh it and restarted as well
    ty in advance
  • Coptech
    worker drone
    • 460
    Re: Ricoh mp c5503
    Is it set manually in user tools instead of set for auto detect?
    • FrohnB
      • Jul 2017
      • 1919
      Re: Ricoh mp c5503
      +1 on what Coptech said.
      Also the obvious, did you move the end fence and side fences into the correct position?
      Omertà
      • heath03
        • Jul 2018
        • 80
        Re: Ricoh mp c5503
        its set to auto and I double checked the guides?
          • 37628
          Re: Ricoh mp c5503
          You have either a tray width sensor or tray set sensor or both. The set sensor is a multi position micro switch that determines whether or not the tray is installed and also reads the position on the cam on the bottom of the tray that is controlled by the position of the end fence,. This checks the length of the paper in the tray.
          • Billabong87
            • May 2019
            • 5
            Re: Ricoh mp c5503
            ty in advance
            in the service mode check 5181 and 5131..
