MP4002 Window Authentication
  • windcopier
    • Apr 2019
    • 51
    Hi guys
    I have facing some problem of while login by using the window authentication by link with Window AD Server.
    The setup i had check is correct but only thing is it require 30 second to login everytime and that is to long for a user waiting.
    I dont know what happen and i have been check all the setting is correct and i had event upgrade the latest firmware also the same.
    Is there any setting that i had miss?
    kindly advice with many thanks~
    Re: MP4002 Window Authentication
    Originally posted by windcopier
    Hi guys
    kinda hard to tell if you don't POST the settings you are using!
