Ricoh same as Kyocera parts?
  • JayPaul
    • Oct 2012
    • 305
  • francisco
    • Nov 2009
    • 168
    Re: Ricoh same as Kyocera parts?
    MP 501 is a Kyocera machine with a diferente controler and a android panel.
    • JayPaul
      • Oct 2012
      • 305
      Do you know if Kyocera also sell this model and what model it is?
      They will be using the same feed tyres but ricohs will be far more expensive
      • francisco
        • Nov 2009
        • 168
        M 3655idn--M 3665idn
        • JayPaul
          • Oct 2012
          • 305
          Thanks for that
          One of the only models I can't get parts for, typical.
          How did you know that was the same model, did you read it somewhere or just general knowledge?
          • francisco
            • Nov 2009
            • 168
            I work with both brands
            • JayPaul
              • Oct 2012
              • 305
              Do you know what I just found a massive guide of all kinds of brands that use each others parts and models etc and Just found these parts through kyocera and just as I thought only a third of the price. Win.
              • davel
                • Oct 2011
                • 1104
                Iwoul be looking to see if pcu, dev and fuser are the same and cheaper.
                  • 30210
                  Most likely Kyocera rebrands it's printer for Ricoh as Kyocera printers continue to struggle for market share
                  • davel
                    • Oct 2011
                    • 1104
                    Because they are a POS.
                    • francisco
                      • Nov 2009
                      • 168
                      only board in drum unit is diferente ,and the toner chip also.
                      i had never try ,but i will ,when i need.
                      • usta
                        • Oct 2013
                        • 44
                        tire set same. You can use
                        • usta
                          • Oct 2013
                          • 44
                          electronic cards and software ricoh. spare parts kyocera. chip differences.
                          • mansart
                            • 852
                            Machine Equivalencies
                            • morgansterne
                              • Oct 2007
                              • 83
                              The entire PCDU units are compatible with each other -- I work for a dealer that sells both and had to try this for troubleshooting light copies on a ricoh mp501.
                              The toners are not compatible however due to the ID chips.
                              I had light copies twice -- first time was engine board, second time (on different machine) was the high voltage board.
