4503 Office 365 (Business) Scan
  • Methedor
    • Nov 2016
    • 69
    Hello. I know at a glance that this should be under connectivity. However I think there must be some setting in the copier that I am missing; maybe SP. I keep getting a transmission error and Options 1 and 2 (MX Record) of Microsoft's connectivity failed. However when a temporary machine (another 4503) was placed in that the standard smtp.office365.com functions fine. Here has what has been tried with Local IT's assistance:
    1) smtp.office365.com
    Port: 587, 465, 25
    SSL = ON
    SMTP AUTH: Correct Credentials (The password was even reset to ensure correct password)
    2) MX Record
    Port: 25
    SSL = On and Off
    SMTP AUTH: Both On and Off
    3) Attempts at making a connector AKA Microsfot's Option 3
    4) Bypass Intelligent Switches
    5) Removed from Client network to Office
    6) Gmail was previously working (Client Cooperate decided to Migrate to Office 365) Was able to get connectionat office using non-Office 365 SMTP.
    7) The Machine at Client's second location works with MC Records. Have done a Data Export with Unique, Import to troublesome unit failed.
    8) Firmware was updated
    9) System Log has indicated "SMTPC: received error code [550] (8000)" Looking the Error code up it appeared to be variants of: The target mailbox doesn't exist. Local IT was able to log into the authenticating email account.
    So as you can tell I think there is something specific to this machine that isn't playing nice with Office 365. Is there something I am missing? I've been trying to figure out a correct configuration of STUNNEL on my laptop in the office. So far I haven't been able to get it to connect.
    Thank you all for reading and responding.
    • 30294
    Re: 4503 Office 365 (Business) Scan
    Office 365 only supports TLS 2.0 , NO SSL Ricoh's don't support TLS
    However in Office 365 their IT can setup a mail relay
    or go back to gmail
    3rd party app STUNNEL not recommend as ALL future email calls are on you.
    • sandmanmac
      • 3981
      or go back to gmail
      Agreed. This was my first thought as I read through the post. Why can't they continue to use the credentials from a Gmail account for sending.
      Unfortunately, I don't have any advice on fixing the smtp.office365.com setup, but when I run across a similar situation, as I did yesterday, I find it easier to simply setup an SMTP2go account for the client, and configure it that way, rather then spend hours trying to sort out something that may not have a solution. They also had a couple of older machines that certainly wouldn't have worked with office 365.
      In my case, I often end up being the their default "IT Person", and they just want a solution
      • Methedor
        • Nov 2016
        • 69
        Re: bsm
        Thank you for the response. However I recall that at least the 4503 has TLS 1.2, which admittedly still isn't TLS 2.0. That being said the current 4503 that is there is functioning using Port 587 without issue. wouldn't it be rejected if the machine couldn't support TLS 2.0? Have I misunderstood something? Additionally, Thank You for the Stunnel warning/advisement.
        Re: Sandmanmac
        Thanks for your response as well. It is a company and they have decided what they want. If it doens't function like they'd like they will move to a different vendor. I would love them to have stayed with Gmail. I believe it was a Business level account. As for the specific question of using the old credentials. I didn't specifically ask as they were fairly insistent and of course would reference the one I got to work by recommending MX records and now the current replacement.
          • 37532
          This link is from Microsoft. How to set up a multifunction device or application to send email using Office 365 | Microsoft Docs
          • JayPaul
            • Oct 2012
            • 305
            Have you set the administrator email address (in file transfer) the same as the smtp auth email address?
            Also is it on same or different ip address from previous machine, sometimes there has to be an exception made for the copier to scan (maybe by ip address im not sure)
            Lastly just incase you hadn't already done so, check gateway and dns settings are all correct.
            • Methedor
              • Nov 2016
              • 69
              Re: Slimslob. Thank you. I had already referenced the document. Though admittedly there might of been something I missed on the Connector in option 3. The steps are fairly prominent.
              Re: JayPaul
              "Have you set the administrator email address (in file transfer) the same as the smtp auth email address?
              Lastly just incase you hadn't already done so, check gateway and dns settings are all correct"
              The Admin Email matches.
              Matched the IP and Gateway while it was on site.
              The DNS was correct as well while it was on site.
              I now have it set to settings in our office. And the unit we have there as a temp was able to use Option 1: Smtp.Office365.com Port 587 SSL On SMTP Auth ON (etc).
              And the temp unit is the same model.
                • 37532
                Re: JayPaul
                Depending on the model Ricoh, TLS though not shown as an option merely by setting the proper Port before selecting SSL
                • skinnyb
                  • Jul 2008
                  • 291
                  I've never had any trouble with office 365 and the newer (ie 03 and up) machines. smtp.office365.com, ssl on, port 587, valid credentials in smtp auth and admin email. Might try doing a NCS clear in service mode to reset all network protocols back to default.
                  Sent from my LM-V405 using Tapatalk
                  • Zaxxon
                    • 608
                    Try another user/password for the office365 login, that helped me, don’t know why.
                    The informations worked on 4 MFP but not the 5. Then I got the IT people to open a new office 365 account, used that information, it worked.
                    Please start you post with brand, model, problem.
                    • JayPaul
                      • Oct 2012
                      • 305
                      To follow up on zaxxons advice. I just had a IT guy the other day say 'if I create a scans user account I will have to charge the customer because they pay per account'
                      I'm sure not all IT companies will do this but maybe ask the question if you request a new user account, failing that use any other account they will have 1 per person any way
                      • Kimi
                        • Feb 2018
                        • 105
                        Does the SMTP connection test work?
                        Can you set your laptop to the same IP as the copiers then use telnet to send an email using the same configuration as the copier. Telnet should offer an explanation if it fails. I have had to do this before to prove the copier was not at fault.
                        99% chance of network being at fault. I have never had to adjust any TLS or such settings.
                          • 30294
                          IT doesn't charge Office 365 charges for every account license
                          • JayPaul
                            • Oct 2012
                            • 305
                            bsm2: It's just how he worded it, either way there would be a charge for creating an extra account, that is all I was trying to make him aware of.
                            Not pinpointing the IT guy personally as if he was taking the money it's just how he said it
                              • 30294
                              No worries , just getting the information out
                              scan to email will work with correct settings that the customer HAS TO SUPPLY to you. MS keeps making changes to correct there faults. MS doesn't care if they break smb scanning or email as long as there side works.
