SR 5060 SC 720 82
  • monkees
    • Jan 2011
    • 40
    SR 5060 SC 720 82
    2018 sc720 82.pdf
    I have replace sensor , Check the cable
    Do you have any Other casistics?
    thanks
  • COPIERMAN
    • Jun 2009
    • 559
    Re: SR 5060 SC 720 82
    if you have replace sensor try diagnostics for finisher input check to see if it changes state. if not then possible bad wire or the board has gone bad. wire shorted out on frame maybe.
