MPC305 with SC561
  • ricmartinho
    • 142
    [Electrical] MPC305 with SC561
    Hello!
    Here's another one from this beautiful model.
    This one is firing SC561, we reset with SP5810 and it works fine for a few days or hours. It also issued SC562-03 once in April.
    The manual points to 2 different things.
    On SC Table:
    On section Electrical Components Defects:
    Where the hell is the Pressure Roller Thermistor Center? I can only see two themistors on the end of the Pressure Roller.
    Anyway, I've cleaned the thermopile, updated FW and replaced the fuser 2 times. The first one was a used fuser and yesterday we fitted a new one. A few hours later SC561 appeared again. I also checked the Fusing connector to see if it was broken like on the old MPC2000/2500/3000.
    I'm going to check the fusing harness and connectors on the boards.
  • ricmartinho
    • 142
    Re: MPC305 with SC561
    I forgot to mention that the error has appeared when the machine is copying/printing, not on standby.
    • Zeldaman
      • Mar 2011
      • 946
      Hi there!
      Had such strange behavior on a DIANA, changed fuser NG. Changed the thermopile BINGO. Hope this helps.
      Greetings...
      • ricmartinho
        • 142
        Originally posted by Zeldaman
        Hi there!
        Greetings...
        I reseated the connectors and so far so good. The Sleep Mode Timer was set to 60 minutes and I changed it to 10min.
        Thanks Zeldaman! If the error appears again I'll replace the thermopile.
