Ricoh mp c3502 smb scanning failure on a VPN tunnel to a server out of state
  • Alias813
    • Jun 2019
    • 5
    [Misc] Ricoh mp c3502 smb scanning failure on a VPN tunnel to a server out of state
    Hello. This is my first post so bear with me.
    I have a customer that is trying to set a scan to smb to a server based in thier Atlanta office. In office scanning works fine. I updated the scanning firmware to 70. No result. I was speaking with thier IT and they have full access tonthe folder fromnthe office computers. When I try to browse the network I get the message about unable to connect.
    Part of my problem is that I am mostly a hardware technician. You got a broken part, I can fix all day. But when I comes to software and network I know just enough to get me in trouble.
    Thanks ahead of time
  • illude2
    • 30
    Re: Ricoh mp c3502 smb scanning failure on a VPN tunnel to a server out of state
    Not sure about the "scanner firmware to 70". I am not seeing that on the Ricoh website but you should install the SMB v2/v3 fix labled
    SMBv2v3 - 4/4/2018 - D111-D142_SMBv2v3_SDcard
    That should fix your issue.
    • tjvincent
      • 280
      When you browse sometimes you have to give it a headstart, try using the server name or IP only and then browse and see if it asks you for a user name/password \\servername\ then hit browse
      • Alias813
        • Jun 2019
        • 5
        Thanks. By 70 I just meant that was the last 2 digits of the firmware. That is the most current one i have. I will take another look though and double check
        • guitar9199
          • Sep 2016
          • 1100
          There was a recent (5/18/2019) Tech Pub on the SMB V2/V3 firmware.
            • 37377
            Two things to check in network settings:
            1. Domain name must be correct. If it is not, anything sent SMB from a device not a member of the domain will be assumed by Windows to be spam and will be rejected.
            2. First DNS must be the domain DNS. If it is not, name resolution will not work. Using IP address usage will be treated as the same as not being a domain member.
            • sandmanmac
              • 3979
              Just FYI....The F/W number seldom changes. It's the letter at the end of all of the F/W numbers that indicates the version
              • Alias813
                • Jun 2019
                • 5
                Ok so the issue seems to be that I have firmware version 70f and I need 70g forbthe smb v2 and v3 support. Does anyone have access to this?
                  • 37377
                  Contact your local Ricoh dealer or branch and have it updated properly.
