FTP Scanning
  • sharpmind
    • Sep 2009
    • 478
    FTP Scanning
    Is there a way to configure FTP scanning in a DHCP network environment?
  • HitMan
    • Aug 2015
    • 170
    Re: FTP Scanning
    Yes
    Sent from my SM-G930F using Tapatalk
      • 29919
      Re: FTP Scanning
      Using hostname of pc
      • sharpmind
        • Sep 2009
        • 478
        Re: FTP Scanning
        Can you share with me the steps on how to do it?What i know is filezilla server using ip address.
        • mincopier
          • Dec 2015
          • 289
          Re: FTP Scanning
          This would be handy. Every FTP I have done has always failed with the hostname. IP worked every time. Though there was one Minolta that hostname did work. SMB has worked for both hostname and IP for me.
            • 37362
            Re: FTP Scanning
            Host name for FTP will work best when you are on a domain and the FTP server is a service on one of your domain servers. In that case the host becomes yourdomain.com or in some cases ftp.yourdomain.com.
              • 29919
              Re: FTP Scanning
              check the copier settings do a ipconfig \all make sure to enter dns and wins settings also domain name
              other option is make that pc a static ipaddress if hostname fails
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Re: FTP Scanning
                FYI:
                • windcopier
                  • Apr 2019
                  • 51
                  Re: FTP Scanning
                  Originally posted by Oze
                  FYI:
                  FTP is only can be done in FIX IP for the PC.
                  You can reserve IP address by setup in the Router setting by capture the PC Mac address.
                  Only this way the IP won't Jump into other IP address.
                    • 37362
                    Re: FTP Scanning
                    mincopier comment that "there was one Minolta that hostname did work" proves you wrong.
                      • 37362
                      Re: FTP Scanning
                      Originally posted by nguyen hong sonn
                      You can take another here
                      http://bit.ly/2x0pXq4
                      This is a link to a knock off site that sells pirated software.
