SP C821 Engine the same as a MPC3501?
  • fshead
    • 2376
    HI
    ARE THESE units interchangeable including ITB units and toner pumps?
    thanks
  • hossam
    • Aug 2010
    • 70
    Re: SP C821 Engine the same as a MPC3501?
    Originally posted by fshead
    HI
    thanks
    toner pumps are interchangeable, ITB units are different mpc3501 ITB.jpgspc821 ITB.jpg
    • fshead
      • 2376
      Originally posted by hossam
      toner pumps are interchangeable, ITB units are different [ATTACH=CONFIG]42901[/ATTACH][ATTACH=CONFIG]42902[/ATTACH]
      thanks
      the pics are one wth cl unit upside vs the other.
      I know the belts are the same and maybe i would have to swap the top metal guides like i did on
      a spc830 ITB unit to fit a MPC3502.
      • davel
        • Oct 2011
        • 1107
        They are the same, minor mod to ITB swap TD sensors and may need to switch pin connection file connectors on PCDU.
        • fshead
          • 2376
          thanks
          I ve swapped the SPC430 drums in the mpc300/mpc401 series and swapped the td sensors to make it work.
          Has anyone ever figured if they mess wth the wire harness or is it a totally different TD sensor with regard to
          color printers vs color copiers?
