MP6001 with sc143 and odd radf issues,
  • fshead
    • 2378
    HI
    I have an old mp6001 on its last leg"1.2mil and showing its age" and it has random adf jams where it doesnt eject the entire original.
    codes 057 and 006.
    The machine does not throw a sc code but it shows up in sc history.
    Optics all look clean and copies from glass seem ok.
    I dont have a parts machine to part out and dont want to shoot a lot of big parts on this.
    any advice.
    • 37641
    Re: MP6001 with sc143 and odd radf issues,
    1.2M? That's the expected life of the drum not the entire machine. Properly maintained these models will go at least 5M.
    SC 143 SBU auto gain error
    The white level cannot be adjusted to the first target level within the target
    during auto gain control.
    Level C error code SCs that are not shown on the operation panel. They are internally logged. Logging only
    SBU board defective
    SIOB board defective
    IPU board defective
    BCU board defective
    Scanner motor defective
    Have you cleaned the white reference, i.e. bottom on left scale on exposure glass? In fact have you actually cleaned anything? A clouded glass may look clean but shine a focused bright light on it and you will see a hazy film. Same is true of mirrors. The film is from ozone generated by the charge coronas and crude in the air.
    Original jam 006 is the registration sensor not seeing lead edge in time. Normally a dirty black reference plate or sensor.
    Original jam 057 is a trail edge jam at the exit. Dirty sensor/reference or dirty exit rollers.
    • fshead
      • 2378
      SBU board defective
      IPU board defective
      BCU board defective
      Thanks.
      optics,white reference,CIS,internal white roller have all been cleaned.
      I know 1.2m is not end of life but if this unit starts to need boards i rather upgrade them to a mp6002 and
      give them" a law firm" a more reliable option.
      I guess what i was wondering is would the "hidden sc143 code" cause adf to jam?
        • 37641
        Originally posted by fshead
        Thanks.
        NO
        • fshead
          • 2378
          NO
          thanks even in adf free run and test mode it would drop out and pause and then go...
          I am feeling time to upgrade plus after 7-8 years on the job it has served its owner well.
          • MIKON
            • Jul 2015
            • 193
            Dj 57 change exit sensor
            Dj 06 clean and lube idler pulleys
            Sc 146 never seen it
            I have a 6001 with 10 mil on it runs like a champ.
            • vargue
              • Oct 2011
              • 404
              i encounter in this before.i send my friend to customer after that sc143 revealed. i went there.i found out that connected harness one of his pins bent over in controller pcb. some times earth out of his position.may be socket loose
              • fshead
                • 2378
                To me it s time vs money vs reliability..
                I deal wth a lot of law firms and a machine down creates issues and
                makes me have to get there fast"good luck in nyc".
                I also have access to low meter clean lease returns so my days of forever on a
                7=8 yr old machine are over.
                And some customer will think if they pour $800 into a machine it will be reborn but
                there are way one can say that....
