Ricoh MPC4504 Bypass Trouble
  • bdesire
    • Oct 2012
    • 62
    Hello, I have a bypass tray that has been used regularly as a envelope feeder.
    The unit will pull the envelope for a whole second and then stop with the separation roller pushing the envelope back in to the tray. So far I have changed all the pulleys as well as all the one way clutches and gears. This is a strange problem that also effects letter size paper. Does anyone know of a part number for the bypass unit ( the entire unit )? in the manual it shows only a duplex unit which is the entire right side door. Thanks in advance.
    Re: Ricoh MPC4504 Bypass Trouble
    look in PM under right door IPB
    • bdesire
      • Oct 2012
      • 62
      Thanks for the quick response but the only option in the parts manual is for duplex unit. There isn't a right door.
        Ok WHICH side is the tray on?
        Look in manual for that side covers...
          • 37483
          The pickup roller is lifting while the feed motor is still turning and the lead edge has not yet the next roller.
          • bdesire
            • Oct 2012
            • 62
            Yes, thats exactly what its doing, what is the cause? Thanks
            • Mark Bbb
              • Jun 2012
              • 1662
              Copypaper has always a size limitations on printers...
              Perhaps the size of the enveloppe is to small to fit the minimum standards?
              • bdesire
                • Oct 2012
                • 62
                Its also happening on letter size paper.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Are all paper settings correct?
                  Fix the by pass paper size to A4.
                  Print with on A4 paper
                  Same problem?
                  • bdesire
                    • Oct 2012
                    • 62
                    Same problem?
                    I don't have A4 paper but it happens with letter, legal all sizes.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      is the jammed paper a little bit damadged (a notch) at the leading edge?
                      Perhaps something in the paper path is blocking the paper
                      • bdesire
                        • Oct 2012
                        • 62
                        I don't see any notches, I have parts on order, I'm thinking maybe either the actuator or the entrance sensor may be faulty. I will let you know what I find out.
                        • Coptech
                          worker drone
                          • 460
                          Isn't there an SP on the 4504 that commits the bypass to either short or long paper? In other words, it only detects width. Depending on how sp is set, will feed 11" LEF or 11x17 but not both. Consequently, it will feed 11r or 8 1/2x14. SP 1007-001 sets priority length detect.
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            did it actually worked before with enveloppes?
                            Where there no problems before a certain time?
                              • 37483
                              The first thing to replace is the full set of bypass rollers. The next is to increase the registration loop.
