Ricoh Scanrouter . Can it be set to forward to an IP ie IPFAX address. Please help
  • garf004
    • Sep 2025
    Is it possible to setup scanrouter pro to fax from a 1224c with fax to a 3025 with IP FAX via the scanrouter software?
    Any scanrouter setup info would be helpful. Never used it ? ie How do you put in a server ip at the start? Tried & keeps saying cant find computer.. Sales info says it should ?
  • ZeusGT
    • 271
    I believe you can with scanrouter PRO only. I've had several client who needed it for that feature. It's been a long time since I've messed with scanrouter, but I believe that you set the server's i.p address once you set up the destination.. I don't quite remember...sorry
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
