MP3554 type machine with Smart Op Panel- Add Fax icon
  • RandyW
    • Jan 2013
    • 213
    We have a MP3554 machine with the Smart Op Panel- picked up used.
    It has a Quick Fax icon on it. How do you add the "regular" Fax icon? Is that an app that gets added to the Smart Op Panel?
    I've added plenty of icons by using the long hold on Classic applications under Program on other Smart Op Panels but didn't see it on this one.
    Is that part of the LegacyUI? Or Simple Fax?
  • guitar9199
    • Sep 2016
    • 1100
    Re: MP3554 type machine with Smart Op Panel- Add Fax icon
    It SHOULD be under the Long Hold "Classic Apps" under "Classic Fax". If it's not there, you might need to update the copier firmware and SOP system software.
    • UNICORNico
      • May 2018
      • 308
      Originally posted by RandyW
      We have a MP3554 machine with the Smart Op Panel- picked up used.It has a Quick Fax icon on it. How do you add the "regular" Fax icon? Is that an app that gets added to the Smart Op Panel?I've added plenty of icons by using the long hold on Classic applications under Program on other Smart Op Panels but didn't see it on this one.Is that part of the LegacyUI? Or Simple Fax?
      If the "icon" is not displayed, try reinstalling the "app", since in these new models, the FAX function (among others) operates by means of an application installed on the system, of the device itself.I had a similar problem, but in this case they did not run correctly.
      "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
