RicohFirmware
  • CrapAimer
    • 296
    RicohFirmware
    Hi All
    been trying to upgrade the firmware on a MP C3502 and a MP 301 but it doesnt reconize it, been doing this the same way for years but for some reason it wont do it ? any ideas ??
    Regards
    George
  • COPIERMAN
    • Jun 2009
    • 559
    Re: RicohFirmware
    can you give more information . does copier display show getting ready to down load firmware if not then not seeing sd card. One thing if you have to big of memory card wont work. I tried using 256 g sd card and would not work most you can go for right now is 128g sd card . check software make sure it starts with romdata folder showing.
    • guitar9199
      • Sep 2016
      • 1100
      Re: RicohFirmware
      C3502 and MP 301?? I wouldn't use an SD card larger than 2 GIG on them! I don't think the controller on the machine will recognize anything more than 2 Gig. Once you get to the "3" series and up, I think the controllers are a little more forgiving.
      • COPIERMAN
        • Jun 2009
        • 559
        Re: RicohFirmware
        sorry i type wrong size was to be 128mb sd card.
          • 37447
          Re: RicohFirmware
          The SD card might need to be formatted. For bast results use the Panasonic format utility. You can find it on TSRC.
          Another possibility is there might be something other than the romdata folder on the root directory of the SD card.
          • morgansterne
            • Oct 2007
            • 83
            Re: RicohFirmware
            you can also try doing remote firmware with a laptop. It's slower since you can only do one at a time, but if you get engine and system first you could try the sd card again.
            • zed255
              How'd ya manage that?
              • 1024
              Re: RicohFirmware
              Make sure firmware updating is not set to 'Prohibited' in User Tools, under extended security.
              • eddy out
                • Oct 2016
                • 359
                Re: RicohFirmware
                301 bundle is romdata last time i used it. on the 02, be sure not to use greenline, and i don't see a pkg. give more info...
