IS two sided copying available on this model?
  • fshead
    • 2376
    hi
    I barely sell these small boxes but placed one a few weeks ago and cant figure auto duplex.
    model is a ricoh SP C242SF..Tried doing it from adf but single only...
    am i missing something?
    thanks
    OP MANUAL SAYS:
    1. Press the [][] keys to select [2 Sided Copy], and then press the [OK] key.
    2. Press the [][] keys to select the binding method and orientation, and then press the [OK] key.
    3. Press the [User Tools] key to return to the initial screen.
      "2 Sided Copy" appears on the display, indicating that the machine is now in 2-sided copy mode
  • StephenB
    • Aug 2015
    • 240
    Re: IS two sided copying available on this model?
    Specs show it auto duplex is standard.
    It looks very similar to a Ricoh SP C261 we have, the ADF has a scanner built in for the 2nd side.
    Duplex copying is done thru the ADF
    • Luther
      • May 2006
      • 682
      It does not do 2>2 sided thru the adf just 1>2 sided
      • fshead
        • 2376
        I can have him take two sheets thru ADF and try to make a duplex copy but i cant see where the 1side copy is suppose to go inside machine..
        i wanted to sell him a SP5200 BUT HE said it is too big so this was option 2...I dont have a spare on i can play with.
          • 37447
          If it is an ADF it does not duplex. Duplex feeder would be ARDF.
          • sandmanmac
            • 3981
            I guess colour is not necessary then Andy?
            Those SP C242's are a $hitbox imho. I wouldn't suggest going down that road.
            MP301 is nice, compact, and reliable, and as you know, I've developed a hate for those SP5200's
            • davel
              • Oct 2011
              • 1099
              Strange choice colour when only need B/W, will not do 2>2
              • fshead
                • 2376
                thanks
                i sold a bunch of the c320dn printers and they worked fine and the engine,toners are the same as the spc242 series..
                they dont need color but need to do doublesided.
                I ran off 50 copies and fed it again to do the 2nd side and no issues.
                those pressure rollers on the 5200 can go but that seems to be with a lot of the ricohs
                • fshead
                  • 2376
                  thanks
                  but can it do single to double.2>1
                  I didnt think these little boxes can flip both side thru the ADF, which is ok
