C2503 stops responding
  • tinfox
    • 317
    Tried to print all SP double sided, it gets to page 60 of 61 and hangs. I tried that twice with the same result. Trying to copy results in the the screen saying "copying" and nothing happens. Tried to format the hard drive and machine immediately hangs.
    This is probably a bad hard drive causing the issue?
    Sent from my moto e5 supra using Tapatalk
  • DonPedro
    • Feb 2019
    • 14
    Re: C2503 stops responding
    This can be hdd. The fastest way to check this out is replace the hdd + format + stamp data. If you don't have new hdd then try format using PC. Check also connection between hdd and controller.
    • emiliorsg
      • Jul 2018
      • 140
      Something similar happened to me with the same model that started printing and then blocked and stopped printing and was the hdd.
      • tinfox
        • 317
        It's was the hdd. TY
