MP 4002 network connectivity
  • scot88
    • Jun 2012
    • 20
    [Misc] MP 4002 network connectivity
    I have a MP 4002 / D129 that won't connect to the customer's network, or my laptop.
    Took a known working controller board out there today, same problem. Brought their controller back to my office and it works in the machine I pulled the controller from.
    I did check the 5985 (on board NIC on or off) and made sure it was set to 1.
    Any ideas?
  • davel
    • Oct 2011
    • 1107
    Re: MP 4002 network connectivity
    Is your laptop connected directly to machine with network cable.
    • scot88
      • Jun 2012
      • 20
      Yes, did the same at the shop, plug the machine directly into my laptop via a CAT5 cable
      • skinnyb
        • Jul 2008
        • 291
        802.1x turned on? I have seen it happen before inadvertently. Note the network settings and do a restore default is usually what I do when this happens.
        Sent from my LM-V405 using Tapatalk
        • sandmanmac
          • 3981
          x2 on that. Had it just a couple of weeks ago when some 'smart person' was fooling around in system settings
          • scot88
            • Jun 2012
            • 20
            Thanks,
            I suspect that could be the case, customer was trying to use one of those TP link wifi range extenders to be able to connect the machine. The machine doesn't have wifi, but I bet they turned it on trying to get it to connect.
            • keithxxiii
              Just a tech
              • Nov 2014
              • 469
              X3 on 802.1x. Had 2 cases for the last 2 months
              Aye! Cut the crap
                • 37514
                802.1x is normally for Ricoh's very expensive internal WiFi option. It is also used with some high security authentication systems.
                • Notrons
                  • Apr 2016
                  • 71
                  Are you referring IEE 802.1x Authentication for Ethernet, located in Network setting?
                  I had a job a few weeks ago that was doing the same thing. I had to switch it to inactive to connect it to the network.
                  • skinnyb
                    • Jul 2008
                    • 291
                    That's it. I couldn't remember exactly what it was called... Has caused me grief more than once...
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      I think we've ALL had this at least once from the sounds of it.
                      I.T. numpties playing with settings and turning IEE 802.1x Authentication for Ethernet to Active
                      • scot88
                        • Jun 2012
                        • 20
                        That was it, 802.1x was set to active, set it to inactive and was able to connect.
                        Thanks for the help.
                        Scot
                        • keithxxiii
                          Just a tech
                          • Nov 2014
                          • 469
                          We had a tech replace the controller board because of this.
                          Aye! Cut the crap
                          • slot
                            • Jul 2008
                            • 341
                            the first thing i do now with these calls is print out the configeratiobn page and see if is enabled customers are nightmares for this.
                            • Kimi
                              • Feb 2018
                              • 105
                              Almost happened to me the first time - thankfully Ricoh asked me to check the setting first!
