Ricoh MP C307 first one
  • COPIERMAN
    • Jun 2009
    • 553
    i just purchase off lease first only. i notice in user tools under screen features there is a wifi setting. Is this feature only for browsing the web. I notice if you turn on and connect and you go to machine feature then to interface no ip address and there is no wifi icon either. i try looking for information but haven't found what is use for.
  • skinnyb
    • Jul 2008
    • 291
    Re: Ricoh MP C307 first one
    That wifi is for op panel only (ie web browser.) does not port over to the machine itself for printing/scanning. 2 separate interfaces. There is a wireless card for machine functions available although it is crap. Plug it in ethernet like all others and good to go.
    Sent from my LM-V405 using Tapatalk
    • Kimi
      • Feb 2018
      • 105
      As above, the wifi is for the ops panel only, however it does allow you to print over TCP/IP but there is no facility for network scanning.
      • COPIERMAN
        • Jun 2009
        • 553
        ok thanks for info
          • 35067
          Not sure as to this model but on some SOP the WiFi is short range.
          • Codex
            • May 2008
            • 683
            Im not sure if there is no kind of port forwarding for the scanner...
            Inviato dal mio SM-G935F utilizzando Tapatalk
            Memento Audere Semper
