Gestetner DSM 627
  • stevee104
    • Mar 2007
    • 214
    Gestetner DSM 627
    Have a machine that has a bad hard drive on it,i removed the hard drive and it gives me a error code sc870 but the machine still works,my question
    is can i remove this code some how and the second question is how do i
    format a new drive if have to put a new one in.The reason i removed the
    hard drive was i never could get the machine to get out of please wait mode.
  • bonnie750
    • 302
    enter service mode and use 5832-1 to format all. other choices are available in there as well. I would reinstall the hdd and try formatting that first, if that fails replace the drive
    • Shadow1
      • Sep 2008
      • 1642
      Even if 5832 works have a new drive on standby - they usually fail again within 3 months
      73 DE W5SSJ
      • stevee104
        • Mar 2007
        • 214
        Is the service mode on this machine c-1-0-7-clear\stop
        • SGT_Snacks-64
          • Oct 2007
          • 157
          Sometimes the hard drive doesn't need to be formatted on these machines, simply installing it will make the machine work, but format it anyway for good measure using the SP mode stated above.
          Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
          Asus P5E-VM HDMI
          4GB (2x 2GB) Corsair XMS Xpert II RAM
          ATi Radeon 4870 512MB GFX Card
          2x 74GB WD Raptor Sata HDD (RAID 0)
          500GB Seagate Barracuda Sata II HDD
          500GB Hitachi Sata II HDD
          600W500att OCZ PSU
          -TOTAL HDD SPACE 1148GB-
          • stevee104
            • Mar 2007
            • 214
            Have installed a new harddrive and formatted it with code 5832-1 and machine still will not boot up untill i remove hard drive. Is there anything else i need to do the hard drive to get it work.
            • Shadow1
              • Sep 2008
              • 1642
              Check for +5V and +12V on the HDD power harness if these are in spec you have a bad data cable or controller board.
              73 DE W5SSJ
              • mrgoodcopy
                TechMgr
                • Dec 2007
                • 49
                Replace with no less than an 80GB, you should'nt have to format it.
