DX3243 PriPort
  • Staggan
    • Jan 2017
    • 54
    DX3243 PriPort
    Hello
    I am looking for some advice on a Digital Duplicator, PriPort machine...
    The printed text is randomly moving up and down the page....
    I have replaced both the pickup and feed roller, as well as the feed clutch but it has not helped at all...
    I can't find anything in the service manual that seems to offer any direction and I am unable to find anyone who has any real experience of these machines..
    I did wonder if perhaps the drum itself was causing problems and could perhaps be moving / worn in some way..
    Any suggestions would be greatly appreciated.
  • davel
    • Oct 2011
    • 1107
    Re: DX3243 PriPort
    I forget, have not seen a duplicator in years but try the digital duplicator forum.
    • Polarbear
      • Feb 2012
      • 1070
      Re: DX3243 PriPort
      Originally posted by Staggan
      Hello
      Hi Staggan
      I would say your registration is messing you around. If the reg clutch is slipping the image will move around on the page from one page to the next.
      Press the GREEN button!!
      • Staggan
        • Jan 2017
        • 54
        Re: DX3243 PriPort
        Hello
        Yes, registration is moving, but there is no registration clutch shown in the service manual...
        I will try posting in the digital duplicator forum...
        • Polarbear
          • Feb 2012
          • 1070
          Re: DX3243 PriPort
          Hello
          I see the registration is driven by a dedicated motor. Check the grub screws holding the pulley to the motor and check tension on the belt attached to the motor, as a slack belt could jump teeth with the speed the machine works.
          • Staggan
            • Jan 2017
            • 54
            Re: DX3243 PriPort
            Thanks for the suggestion...
            I've checked the grub screws on both the motor and roller, checked belt condition and tensioner the belt again...
            Still no joy, the position can fluctuate by 10mm or more...
            I'm wondering if speed is causing issues or if there is a drum issue...
            Any further help would be appreciated
            • Staggan
              • Jan 2017
              • 54
              Re: DX3243 PriPort
              Update
              I have got normal thickness paper working fine, but thicker paper is still slipping....
              I think the issue is pressure on the registration roller which is managed via part of the drum drive... but I can't find anything on it in the service manual...
              I've got the complete roller assembly that sits above the registration roller out and it seems fine...
              Any suggestions would be appreciated
              • Polarbear
                • Feb 2012
                • 1070
                Re: DX3243 PriPort
                Update
                HI. Glad about the progress!
                Do you adjust the thickness lever depending on the paper you are using? There is such a lever on the feed side above the paper table.
                • Staggan
                  • Jan 2017
                  • 54
                  Re: DX3243 PriPort
                  Hello
                  Yes, I am adjusting paper type using that lever...
                  • Polarbear
                    • Feb 2012
                    • 1070
                    Re: DX3243 PriPort
                    Update
                    Hi. Have you checked the solenoids that release the pressure roller below the drum. They sometimes stick and can cause uneven pressure as well.
                    Sent from my SM-G950F using Tapatalk
