sc 641,sc 641*, and sc 670 codes
  • fshead
    • 2376
    i just swapped out a mpc40sr that i sold months back,that customer complained
    would throw sc codes.
    The machine had all the latest FW and was in a hard place to get to so i upgraded him
    to a mpc401sr and made the swap.
    Upon testing the machine i get no codes and did see a small paper shredder sharing the same outlet.
    As i can only ck the last 10 codes I dont know if this was a noise issue from the shedder.
    machine has a ricoh surge protector
  • FrohnB
    • Jul 2017
    • 1919
    Re: sc 641,sc 641*, and sc 670 codes
    SC 641 does not show up in SM. Is it 541?
    As for the SC 670
    Engine start up error CTL
    The ready signal from the engine board was not detected.
    Case 1
    No /ENGRDY signal asserted at power on, or when machine
    left low power mode.
    No response from EC from engine within the specified time at
    power on.
    No response from PC from engine within the specified time at
    power on.
    No response from SC from engine within the specified time at
    power on (MFP module only).
    Write to Rapi driver failed (no destination found at PCI).
    Case 2
    Unexpected error occurred after /ENGRDY signal asserted.
    Check the connections between the controller and BCU
    Replace the BCU for 100% failure
    If occurrence of the error is sporadic, the firmware may need to
    be updated, or the controller board or PSU requires
    replacement
    EDIT: This is from the C401sr service manual. Below is the C240 manual, which DOES have the SC 641.
    641
    CTL
    D
    BCU control data transfer abnormal
    A sampling of the control data sent from the BCU reveals an
    abnormality.
    Controller board defective
    External noise
    BCU board defective
    1. Replace the controller board.
    2. Replace the BCU.
    and 670 is an engine start up error (Replace BCU)
    Omertà
      • 37471
      If you meant MP C400SR then SC 641 is in the Service Manual.
      A sampling of the control data sent from the BCU reveals an abnormality.
      • [*=1]Controller board defective
        [*=1]External noise
        [*=1]BCU board defective
      2. Replace the BCU.
      A small shredder plugged in the same outlet could definitely generate enough RF noise to blow right through a surge suppressor as well as transmitted noise.
      • fshead
        • 2376
        thanks but so far it is not coding out..
        I will leave it plugged in for a few days and run another 100 pages to see..
        i guess also use print/scan functions
