need confirmation that this is the right SOP package FW
  • fshead
    • 2376
    HI
    i have a mpc3003 wth a SOP panel that i want to update the package fw via sd card.
    Unit is telling me to re check i am using the right one..
    Not sure if its valid warning or not..package fw
    so the new FW IS 1465519M 88,900KB IN SIZE
    The one now in UNIT is D1465506X
  • guitar9199
    • Sep 2016
    • 1100
    Re: need confirmation that this is the right SOP package FW
    D146-D147_All_SmartOperationPanel_v27.00_20180713_SDcar d is the file name on TSRC
    Inside the folder, here is the "Read Me" file....
    <<Package>>
    package_ALL [METC1JLCHa_pk]
    D1465519M Ver. 26.01 -> D1465519N Ver. 27.00
    <<Separate>>
    System/Copy [METC1JLa_system]
    D1465575J Ver. 3.22 -> D1465575K Ver. 3.23
    Network Support [METC1JLa_net]
    D1465567X Ver. 12.100.1 -> D1465567Y Ver. 13.01
    Hope this helps.
    • Gary Bowen
      Bowdog
      • Mar 2008
      • 250
      Your current SOP Package firmware is a very old version (15.2). The current SOP Package firmware is D1465519N (v27.00), so there is actually a version newer than the one you plan to update. There may be individual firmware modules that are even newer than what is available in the package firmware so check after you do your update and do any romdata/D146 updates as necessary. Probably would be a good idea to update your Java sdk as well.
        • 37483
        D1465519 is the proper number for the package firmware for the MP C3005/C3503 product line. The letter M is the version. I have no idea what D1465506X is but based on the X version level, it might be an older, by a number of releases, version. As such, the D1465519M may not contain all firmware that was updated by versions released between D1465506X and D1465519M. I would suggest that you update with module firmware first, then load the package. In the future you need to load each package update as it comes out to avoid the problem of missing a modue update that might only be contained in 1 or 2 packages.
        • fshead
          • 2376
          thanks all
          I bought the ver 26 last year and i did use it with previous machines i sold.
          Does it pay to try to get the next ver?
          If so anyone feel like helping my cause..
          • fshead
            • 2376
            i ended up using what i had and it correct for a SOP mpc3003
