what does Java allow on a MP 6002 and can i uninstall?
  • fshead
    • 2376
    HI
    i am working on a MP 6002 THAT HAS THE JAVA card installed and dont think customer has any need for JAVA.
    Also i want to pop a PS3 card so they can print from their mac books.
    If I kept the card do I MOVE JAVA TO SLOT 2 AND PS3 to slopt 1 and merge?
    thanks
    • 37533
    Re: what does Java allow on a MP 6002 and can i uninstall?
    Before removing the JAVA SD card, stop it in User Tools. If JAVA is running and you power off and remove the JAVA SD card there is an outside possibility of cratering the Control PCB.
    • skinnyb
      • Jul 2008
      • 291
      Java and PS3 can't be merged. If they aren't using it, just uninstall in user tools and take it out. It can stay in slot 2 if you need it though, just have to uninstall anytime it's removed to do firmware updates.
      Sent from my LM-V405 using Tapatalk
      • fshead
        • 2376
        thanks all
        I should be able to uninstall it via extended features?
        No need to disable it in serv mode
          • 37533
          Originally posted by fshead
          thanks all
          I believe that disable in SP is for newer models with embedded JAVA.
          • skinnyb
            • Jul 2008
            • 291
            Correct.
            • fshead
              • 2376
              I just uninstalled it and it seems fine..
