Ricoh mpc 5000 (lower copy option speed)
  • omorales
    • Mar 2015
    • 86
    Hello friends, I have a client that has problems with blemishes in the fusion unit (only when copying in high coverage), when copying characters is fine.
    The printing option was lowered by the driver, but the copy option did not find sp.
    The other solution would be to raise the temperature a little, but if possible lower the speed a bit in the option to copy.
    Thanks for your attention
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Ricoh mpc 5000 (lower copy option speed)
    You DO know how to set the machine tray settings to (for example) Thick 2 to slow down copy jobs right ?
    I mean...surely this is something that you've already tried before asking here.....correct?...SURELY.....???!!!
    I see a red card ...so maybe not?
      The other solution would be to raise the temperature a little, but if possible lower the speed a bit in the option to copy. Thanks for your attention
      sounds like you are in the wrong profession Hoss.
      THAT would be covered in the SM... if you don't have the basic tools ..QUIT You give the rest of us a bad name.
      • keithxxiii
        Just a tech
        • Nov 2014
        • 471
        MPC5000 is meant to do 50 CPM. You should have checked the health of your "FUSION" unit and paper type before trying to do adjustments that are not recommended. Use the machine as intended.
        Aye! Cut the crap
        • Zaxxon
          • 608
          Please start you post with brand, model, problem.
