ricoh mpc6502 access to web error 403 forbidden looking forward for help
  • levantin
    • Aug 2019
    • 26
    ricoh mpc6502 access to web error 403 forbidden looking forward for help?
  • keithxxiii
    Just a tech
    • Nov 2014
    • 471
    Re: ricoh mpc6502 access to web error 403 forbidden looking forward for help
    print interface settings and check for access control.
    or lower down network security level to 0.
    this has similar topics answered on this site.
    Aye! Cut the crap
    • levantin
      • Aug 2019
      • 26
      Can you only use yourself?
        • 37556
        Did someone try to create a device certificate? An improper device certificate will cause your error. If so try resetting NCS, SP 5801-11.
        • levantin
          • Aug 2019
          • 26
          I have tried but it's failed. and tried 5801-01 yes
            • 37556
            If you ran 5801-01, I hope you have the birth certificate.
            • skinnyb
              • Jul 2008
              • 291
              Exactly. If you did 5801-01, the lack of Web Image Monitor access is the LEAST of your worries now...
              Sent from my LM-V405 using Tapatalk
                no Slim said 5801-11 not 01...
                01 can be a MAJOR HEADACHE .. do you have a service manual?
                or at LEAST the list showing SP mode definitions?
                as mentioned, you are in for a TON of work -=IF=- you have no service manual
                5801-01 should be THE very last resort.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Especially on a color machine. Good grief.
                  • keithxxiii
                    Just a tech
                    • Nov 2014
                    • 471
                    here we go again...
                    You could have waited for other inputs. Well, good luck putting back the values though
                    Aye! Cut the crap
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      • Coptech
                        worker drone
                        • 460
                        I thought about scanning them at new machine setup just to save a copy in case it ever got lost but never took it seriously enough to start doing it.
                          • 37556
                          Top technicians print the SMC non-default SP 5990-006 at every service call and keep the last 2 or 3 in case they can't find the birth certificate. With this model you can use SP 5992-006 to export it to an SD card.
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                            some years back, I had all our techs doing just that, plus the network settings pages, too.
                            I tried to get them to put a copy of those on a shared network folder in the office, but I guess that was too much to ask.
                            After begging for about 6 months, and getting almost zero cooperation, I threw in the proverbial towel.
                              Yes.. yes we do.
                              Please keep in mind NOT EVERY BC is the same..
                              Slim hit it on the head..i made one for machine AND one for MY records.
