Savin C3003 Fax issue
  • baggs1972
    • Jun 2019
    • 5
    Hi All,
    I have a customer that their fax line is shared with their phone line, recently the C3003 started answering all incoming call as faxes, a workaround was I shut off auto reception that way tey can at least get their phone calls. Is there a setting for the machine to recognize distinctive rings.
    thanks in advance!
  • zed255
    How'd ya manage that?
    • 1024
    Re: Savin C3003 Fax issue
    No distinctive ring capability on native Ricoh devices. Some of the little SOHO rebrands have it but Ricoh always assumes a dedicated line. You can adjust the number of rings it takes before it answers (it is a setting in the NCU parameters) but not much else.
      • 37652
      You might want get them a line share device. These devices detect the CNG tone sent by the calling fax machine and switch the call to the fax machine.
      • FrohnB
        • Jul 2017
        • 1919
        We use these. "The Stick". We have always had good results with this little product. Same thing that Slim is talking about. Fairly cheap, and super easy to set up.
        Omertà
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Here in Australia distinctive ring can be set up via the provider.
          The customer will be charged by the provider for the privilege.
            • 37652
            Same is true for most areas. Doesn't help if the fax does not support distinctive ring.
            • jonhiker
              • 661
              Thanks for the info. I have customer that this would work just great for them It is a small law office in a small town.
              • baggs1972
                • Jun 2019
                • 5
                I figured that out, but for some reason they were able to use the fax and phone on same line with this machine for several years, a few weeks ago she had a incoming fax stuck in queue and could clear it out so the tech onsite had done a SRAM clear on fax..I assume that whoever installed it must have done some "tweaking" on fax setting to get it to work..
                • biggsy
                  • Nov 2011
                  • 5
                  Originally posted by baggs1972
                  Hi All,
                  thanks in advance!
                  In Australia it is called Duet - Fax SP mode NCUP 09 change from 144 to 90, NCUP 10 change from 001 to 000
