WSD scanning Ricoh AFMP 5054
  • aviso66
    • Dec 2012
    • 202
    Hi, does any one know how to get WSD scanning ricoh to work?
    I have tried,
    enable wsd from webimage,
    enable wsd from initial scan settings.
    i am using windows 10.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: WSD scanning Ricoh AFMP 5054
    WSD is a swearword. Use scan to folder instead, much easier on a single PC setup.
    Hit it.
    • mikadonovan
      • May 2008
      • 2931
      Even installing a printing device as a WSD is a mistake. It glitches, and it ceases to function for no apparent reason whenever it wants to. I cant even imagine trying to reliably scan from a WSD. Guaranteed weekly service call, I would say.
      NEVER ASSUME ANYTHING
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        What THEY said ^
        We turn off everything WSD related at run up.
        • aviso66
          • Dec 2012
          • 202
          Wew thanks for the info. i thought that would be the best options to be used for windows 10 because we have an AF MP5002 seems to have scanning issue (scan to folder to win 10)
            • 37544
            Web Services for Devices or Web Services on Devices (WSD) is a Microsoft network connection protocol. Even if you could get it to connect for scanning you would still have to use SMB to send the data. SMB is the scanning issue with Microsoft and Apple. Apple discontinued the inclusion of Samba, an implementation of SMB, a few years ago.
            • Mark Bbb
              • Jun 2012
              • 1662
              Your scanproblems are due to the WSD usage (wsd port)!!!
              • rthonpm
                • Aug 2007
                • 2859
                For WSD to work for scanning, you'll also need the Windows 10 Scanner app from the Microsoft Store, or another application that will support WSD. Really it's just a modern equivalent for TWAIN scanning, but it is helpful for scanning photos since you can choose what part of the image to scan and also use file formats not supported by the MFP otherwise like PNG.
                First make sure that your PC can even see the scanner available as a possible device from Settings > Devices.
                Sent from my BlackBerry using Tapatalk
                  • 30332
                  Setup scan to folder using filezilla server or use scan to email
                  You scanning to each pc or a server? or use scan to email
