Ricoh Aficio MP 3350 will not produce postscript output from Windows 10
  • johnwayne
    • Sep 2019
    • 23
    It's a Ricoh Aficio MP 3350 with the postscript SD card installed, connected to LAN with a static IP. My laptop with Windows 7 booted, can print postscript halftones perfectly. When I boot that same laptop with Windows 10 - using the exact PS printer driver that was copied from Windows 7 - the printer will not print a test page, but it will print from coreldraw, but it does not create the halftone postscript output as expected. Everything works perfectly from Win 7. Everything is identical in Win 10 - and it will not produce halftones from coreldraw. Using the 'Ricoh PS UniversalDriver V4.22' as that is a known halftone producing driver under Win 7. The Ricoh site does have V4.23 out - but my Win 10 tests of it would cause the printer's data in light to stay solid with no other activity (for 30 minutes, thereafter I reset the job, was just attempting a test page). Additionally the V4.23 PS driver would corrupt the V4.23 PCL driver under Win 10 because Ricoh used the same version numbers. I do install the PCL and the PS drivers - so that Windows can print "normal" with one printer/driver and print halftones with another. Everything works great in Win 7. I need to be able to produce postscript output from Windows 10 to this machine. Please Advise. I have already tried every other older driver for Win 10 and Win 7 under Win 10, with manually force deleting the drivers and restarting between attempts using pnputil in an admin cmd prompt. It's not a laptop issue, not a network issue, not a printer mechanical issue, it's Windows 10 vs. the known-working postscript driver.
  • keithxxiii
    Just a tech
    • Nov 2014
    • 471
    Re: Ricoh Aficio MP 3350 will not produce postscript output from Windows 10
    Hi,
    I'm guessing the drivers you mentioned were universal PS drivers from Ricoh.
    I would suggest installing the correct one.
    Support for windows 10 was introduced with this version.
    Aye! Cut the crap
    • johnwayne
      • Sep 2019
      • 23
      Originally posted by keithxxiii
      Hi,
      thanks for that info, i tried that file, and chose the 3350 (not the 3350B, as my unit is a D020-17) and I can print a test page and print 'normal' output, however postscript halftone output is not produced when intended. Attached is the test page. Do you know is there some obscure setting in the Windows 10 driver so that postscript gets produced as halftones? the print job from coreldraw IS set properly to produce halftones.
      • Brianneoe
        • May 2015
        • 322
        I don't know if this will help but you can try this. In the Printing Preference tab go to Advance. Change Dithering setting from "Auto" to "User Setting"
        Im using the non universal driver. This setting made it possible to change the dot size and shape in Illustrator when I needed to do a color separation output.
        Good luck
        • johnwayne
          • Sep 2019
          • 23
          Good luck
          You are EXACTLY right! I had just found and tested this myself. In Windows 10, dithering defaults to 'auto' which produces grayscale instead of halftone. Changed it to 'user setting' and now I have halftones. That's 2 days of my life that I wont get back - however a huge thank you to the commenters here. hopefully others will find this post about this poorly documented setting and avoid the headache I had. It's just odd that either dithering didnt default to auto in windows 7, or i happened to just dumb-luck adjust that setting from the get-go in Win 7 without realizing it.
          • Brianneoe
            • May 2015
            • 322
            All good Duke, I wasn't too sure it would help but I'm glad it did
              • 37627
              The only Drivers that have that version are the "Drivers for Universal Print". There is one place and only one place universal print drivers should be used. They were developed for use with pooled printers that are not the same model. Print pooling requires all printer in the pool use the same driver.
              • johnwayne
                • Sep 2019
                • 23
                thanks for that info, hadnt heard that before.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  The universal drivers also get deployed when there are pooled printing apps in place, such as Streamline, Equitrac, or PaperCut.
                    • 37627
                    It was covered at one of the Ricoh classroom training courses I attended.
                    • johnwayne
                      • Sep 2019
                      • 23
                      Good luck
                      6 years later, and a forum letting me necro my own post - YOU'VE SAVED ME AGAIN! bought a Ricoh Aficio MP C4502 and upgraded with the correct postscript SD card - had same issue as 6 years ago. Found this through google search and it clued me in that a settings panel actually has a side-scroll area to get to the dithering setting. C4502: Have to go in to printer preferences > detailed settings > "menu" section (being sure to scroll that narrow box to the right) > print quality > dithering = user setting.
                      This info doesn't seem to exist anywhere else online. This is a fantastic forum for getting things done, and Brianneoe if you're still around - I owe you a beverage!
                        • 37627
                        You are trying to use a 17 year old B/W multi function device that Ricoh discontinued support of back in October. Get rid of the dinosaur. Get something much newer that supports PDF Direct without any additional options.
