Ricoh AF MP 5001 SP firmware validate is it latest.
  • aviso66
    • Dec 2012
    • 202
    Hi, can someone assist me to validate the firmware for ricoh af mp 5001 sp is it the latest version? bec i am having issue scanning to windows 10.
    Module Name Version Part No
    System/ Copy 2.18 D1295760
    Network Support 11.103 D12955754Q
    Fax 09.00.00 D1295753L
    Web Support 1.19 D1295755M
    Web Uapl 1.05 D1295756E
    networkDocBox 3.04 D1295757J
    animation 1.00 D1295742A
    PDF 1.06 D1295734E
    Java VM v10 std 10.01.06 D1295735B
    Scanner 01.13 D1295759E
    PCL 1.18 D1295762N
    Printer 1.12 D1295763J
    RPCS 3.12.19 D1295764B
    Font Exp 1.04 D1295770B
    PCL Font 1.13 D6415758A
    PS3 Font 1.11 D64515763A
    Data Erase Onb 1.03m D3775813
    Engine 1.02.03 D1295700D
    OpePanel 1.03 D1291493A
    LANG0 1.02 D1291499
    LANG1 1.02
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Ricoh AF MP 5001 SP firmware validate is it latest.
    Set up Scan to FTP.
    Your listed firmware is newer than what I can access via the Ricoh Dealer portal as Ricoh Australia has stopped support for this model but I'm pretty sure it won't contain the last batch of SMB firmware.
    You COULD get it to work if you enable SMB v.1.0 on the target PC but Scan to FTP using Filezilla is just as good and only take around 15 minutes to set up if you've never done it before.
    • aviso66
      • Dec 2012
      • 202
      Originally posted by Oze
      Set up Scan to FTP.
      Does it require fixed ip?
      • aviso66
        • Dec 2012
        • 202
        Set up Scan to FTP.
        oops my bet, typo. its af mp 5002 sp
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          I'm just gonna let this sit here.......
          • COPIERMAN
            • Jun 2009
            • 561
            no it is not latest firmware
            Program Name] Network Support [Version] 11.104.1
            Program Name] Scanner [Version] 01.14
            Program Name] System/Copy [Version] 2.20
            Program Name] Web Support [Version] 1.20
            • aviso66
              • Dec 2012
              • 202
              hi thanks, that's for aficio mp 5002sp right?
              • COPIERMAN
                • Jun 2009
                • 561
                if you have a problem scanning to windows 10 then you need to get the latest firmware for that copier so you need to make sure you tell who every that this is model and need firmware for it just make sure it is a reliable person you are dealing with. Ricoh dealer is a good source
                  • 37652
                  The last I checked MP4002/MP5002 were not on the list of models that Ricoh has written SMBv2/v3support firmware.
                  Effects of disabling SMBv1: Multifunction Printers and Laser Printers | Products & Services | Global | Ricoh
                    • 37652
                    The newer a Win 10 computer, the less likely you have of getting SMBv1 to work. When Windows 10 RS3 OS is not cleanly installed, but updated from older OS versions, such as Windows 7 or Windows 10 RS2, the SMBv1 value is inherited from the previous OS version.
                    • FrohnB
                      • Jul 2017
                      • 1919
                      SMBv2v3 Firmware was released 5/8/18 for this model.
                      Current Firmware for 5002 that need updated on your list.
                      -System v2.23 (7/2/19)
                      -Web support v1.21 (7/2/19)
                      -Scanner v1.14 (4/3/18)
                      -RPCS v3.12.20 (4/2/14)
                      -Printer v1.13 (5/8/18)
                      -PCL v1.21 (5/8/18)
                      -NCS (Network support) v11.104.1 (4/3/18)
                      -LCDC v1.10 (12/26/13)
                      -Fax v10.00.00 (2/22/19)
                      -Engine v1.03.03 (7/9/13)
                      Omertà
                      • COPIERMAN
                        • Jun 2009
                        • 561
                        firmware that has been update for smb2/3 was available on 3/29/2018
                        • aviso66
                          • Dec 2012
                          • 202
                          know where i can get it?
                          • aviso66
                            • Dec 2012
                            • 202
                            -PCL v1.21 (5/8/18)
                            are you able to help me to verify my machine firmware was released on what date?
                            • COPIERMAN
                              • Jun 2009
                              • 561
                              you need to find a dealership to update copier.
