RICOH WIA scan how to install?
  • aviso66
    • Dec 2012
    • 202
    Hi,
    Kindly assist if anyone knows how to install a Ricoh multifunctions WIA scanner driver? i have downloaded from the site but there's no WIA.exe that i can istall
    • 30178
    Re: RICOH WIA scan how to install?
    You need to setup scan to folder or scan to email
    • aviso66
      • Dec 2012
      • 202
      scan using WIA driver.
        • 30178
        Usually NO one scans using twain or WIA driver
          • 37479
          Post your question in the correct Copier Technical Forum https://www.copytechnet.com/forums/r...tetner-lanier/
          Be sure to mention the model that you are needing help with since most Ricoh models have TWAIN drivers not all of them have WIA drivers. For those that do, you need only download, extract and install. For some that are downloaded as a self extracting executable, the driver is installed during extraction. Again depending on model some may have network WIA and others will only scan through USB.
          FYI WIA.exe is not part of the driver. You might be used to Paint Shop Pro 9 which uses wia.exe to allow access to WIA drivers.
