Savin 9090 print quality problems
  • Sage632
    • Jul 2019
    • 45
    Hello Ladies and Gents,
    I have a savin 9090 that will print a large black line on the lead edge (or trailing, not sure) and squashes the rest of the print on the page. I recently replaced the transfer belt, blade, and anti-static plate as a response to this issue.
    It only does it for the first print. Successive prints look fantastic. Or if I let the machine rest for a few minutes, it will print on bad sheet and the rest fine.
    I will upload a post of the print soon.
  • Sage632
    • Jul 2019
    • 45
    Re: Savin 9090 print quality problems
    here is the example
    https://drive.google.com/open?id=1vAQj52ZDqTPQW7v646G3GAVDKVZDKPBi
    thx in advance for ur help
      • 37444
      This is a very common when the charge corona needs to be rebuilt and possibly the drum needs to be replaced. The surface of the drum cannot reach full charge before the first sheet.
      • Sage632
        • Jul 2019
        • 45
        I thought it had something to do with the feed...
        Any idea why the image is squashed?
        • zed255
          How'd ya manage that?
          • 1024
          Compressed and blurred image could possibly be loose drive coupling on the drum shaft. I can't say I have seen it on your specific model, but on earlier models like the Ricoh MP5500 it was fairly common.
          Alternatively the drum motor could be weak and jitteriness until things get moving.
          • Sage632
            • Jul 2019
            • 45
            So...
            I have replaced the drum, drum blade, and charge Corona unit. No change.
            Any other suggestions?
            • Coptech
              worker drone
              • 460
              Zed suggested the drum drive. Look on the back of the machine for the drum drive. It will have the flywheels bolted to it. Take them off and make sure set screw is not loose on the drive itself. Changing the drum itself will have no positive effect on the drive to it.
              • Sage632
                • Jul 2019
                • 45
                The drive is nice and tight doesnt seem to be any slippage.
                the most recent print looks like this:
                https://drive.google.com/open?id=11YUXenRljSA16cfFys_9zlSCPJJcLU5t
                  • 37444
                  While you have the fly wheel off, check the continuity from the drum shaft to the frame. It should be less than 10 ohms, preferably less that 5. If not, either the drum shaft ground plate (B070 3685) modification has not been done, TSB#039, or the conductive bearing in the drum shaft stay is no longer conductive. The bearing is not available so the drum shaft stay (B070 3680) will need to be replaced.
                  • Sage632
                    • Jul 2019
                    • 45
                    I checked the continuity from shaft to frame while I had the drum unit out.
                    I use diode check for that.
                    The was none from chassis to shaft.
                    I assume that tsb#039 is some sort bulletin.
                    I have no Ricoh support, and do not know a way to access the bulletins.
                      • 37444
                      You need to use resistance not diode check. Diode check does not show resistance value.
                      • Sage632
                        • Jul 2019
                        • 45
                        So a little update...
                        I replaced the entire drum unit to no avail.
                        I opened up the back of the mfp and watched the fly wheel turn with a few prints and noticed it would slip.
                        It was missing the set screw on the back of the drum shaft.
                        Not sure how a client got a machine without a set screw.
                        I put in the set screw and voila! It works.
                        Thanks for your help everyone.
                        -sAGe
                        • zed255
                          • 1024
                          Thanks for the update. This is what I was suggesting 2 weeks ago in post 5.
                          • Sage632
                            • Jul 2019
                            • 45
                            I know...
                            But when I pulled off the back of the mfp and opened the door I wrongly assumed that it would have all the parts it was supposed to
                            I feel dumb
