ricoh mp c6502 cleaning unit for CPU
  • levantin
    • Aug 2019
    • 26
    Please help me to clear the error
    Re: ricoh mp c6502 cleaning unit for CPU
    did you replace the parts and clear the error message in SM?
    it is clearly outlined in the service manual
      • 37533
      Clear what error?
      • MIKON
        • Jul 2015
        • 188
        Turn off copier
        open lower right side door
        turn copier on
        enter sp 7622 clear part replaced
        enter sp 3701 go to part replaced enter 1 in box
        close lower right side door
        • rthonpm
          • Aug 2007
          • 2859
          Originally posted by MIKON
          Turn off copier
          turn copier on
          This is the only way I've ever been able to get this message to clear.
            • 37533
            Turn off copier
            turn copier on
            When this does not work, check Lubricant End Detection Flag SP 3810-021 K, SP 3810-022 C, SP 3810-023 M, and SP 3810-024 Y. If they are not all 0, the message will not clear. Check that the near end sensors for the lube bars are not shorted.
            • Babujoseph
              • 35
              good information thanks
