Ricoh MP 7001 overtoning
  • copytrust
    • Feb 2010
    • 118
    Hey guys i have a client he has a MP 7001 so i replaced him a new drum - developer - transfer belt etc and the developer had an overtoning in the next 60.000 copies that caused to the drum to filled with toner, replaced again developer and still in the next 70.000 copies he has the same problem.
    Does anyone have any idea all parts and toner in the machine are original.
  • eccelobo
    • 113
    Re: Ricoh MP 7001 overtoning
    Hello!
    Is the toner OEM?
    Did you make the TD Sensor Initial Setting?
    What are the readings of SP2220 and SP2223?
    • copytrust
      • Feb 2010
      • 118
      Originally posted by eccelobo
      Hello!
      Is the toner OEM?
      Thanks for the repply...yes the toner is original and so is the parts
      sp 2220 and sp 2223 ithink thats the VT and VREF? if it is the readings are 3.50 and 3.20, and yes i did the TD sensor when i replaced the developer when the developer was new after the td sensor the values were 2.70 both of them.
      • eccelobo
        • 113
        For a quick test, do you have another development unit to try?
        The drum unit is dirty just with toner or is there developer too?
        Did you disassemble the development unit when replacing developer?
        Check the charge corona, or try with another.
        Is SP2208 "0"?
          • 37478
          You may have a toner hazing problem not an over toning problem. Check that the development filter is properly installed and the filter plate is on top of the filter. Also check the condition of the seals on the development as if they are excessively worn, the development unit will blow toner directly onto the PCU frame.
          Considering the age of the model you could also have worn bushings on the development unit.
          • Codex
            • May 2008
            • 701
            Hello
            Check also the toner supply clutch.... Had similar problem with an Mp6001... Where the clutch remains "on"
            Inviato dal mio SM-G935F utilizzando Tapatalk
            Memento Audere Semper
            • mikadonovan
              • May 2008
              • 2931
              Make sure your filters are clean. Clogged filters raise the temperature inside the machine resulting in a overtoned condition.
              NEVER ASSUME ANYTHING
              • copytrust
                • Feb 2010
                • 118
                Is SP2208 "0"?
                There is no developer in the drum unit only toner I must say that if you turn the development knob the developer unit throw toner dust. The strange thing is that the machine prints fade, if you consider the toner amount in the development unit.
                Στάλθηκε από το G3412 μου χρησιμοποιώντας Tapatalk
                • copytrust
                  • Feb 2010
                  • 118
                  Originally posted by Codex
                  Hello
                  Is there any way to check the clutch?
                  • copytrust
                    • Feb 2010
                    • 118
                    I have remove all the filters from the machine just to be sure before I changed the developer.
                    • copytrust
                      • Feb 2010
                      • 118
                      I mean the ozon filter.
                      • copytrust
                        • Feb 2010
                        • 118
                        Is SP2208 "0"?
                        I was thinking about the developer unit because before I changed it I cleaned the magnetic with metal brush, the magnetic was very dirty, and had a brown coat, after 60.000 copies there was again the same thing!!!!
                        • Codex
                          • May 2008
                          • 701
                          If you opens the right side panel and make an "forced toner supply"..... You can hear the clutch making "click" noises..... And you can see the movement from the right side..... The problem is that often during the work the clutch remains "on"..... This was my case in the Mp6001...... If you have another machine or an Mp7500 (same part number) you can try to change it.
                          • eccelobo
                            • 113
                            Open the door, put an actuator, open the toner hopper to the right and look into the entrance of the toner supply unit. If the transport screw spins at all times, it means that the clutch is activated.
                            • eccelobo
                              • 113
                              If you try another development unit you would find out faster where to check afterwards
