Ricoh MPC3500 SSL
  • Bole
    • Dec 2012
    • 34
    Ricoh MPC3500 SSL
    Hi
    is posible to enable SSL protocl in this MPC3500 12 years old MF copier? In UserMode or SrviceMode. I have problem with Scan to mail.
    thank you
    Bole
  • francisco
    • Nov 2009
    • 168
    Re: Ricoh MPC3500 SSL
    no
    • mincopier
      • Dec 2015
      • 289
      Could try the following:
      SMTP server: relay.appriver.com
      Port: 2525
      SSL/STARTTLS: no
      Authentication: no
      Administrator email can be anything as long as to the right of the "@" is a valid domain. Surprisingly "@gmail" has not worked for us.
      This server is not 100% reliable. It does generally work. Emails sometimes are delayed. Emails sometimes go to junk box depending on filters.
        • 37429
        TLS NO, SSL Yes. You will have to install a site certificate through WIM. See attached for more information. For Firefox users, Google Internet Authority is now found under GlobalSign. How do I setup SMTP over SSL on a Ricoh Family group device.pdf
