Config wifi SG3110SFNw
  • aguatepe
    • Jul 2015
    • 28
    Good afternoon,
    Today I have been involved with this machine model at the home of a client trying to configure the machine with WiFi network.
    I have not been able to configure it either via the web or via the control panel.
    The router has a WPA2-Personal encryption.
    I have configured this other times without problem in other clients
    I wonder if this equipment is compatible. I have updated the firmware to the latest version.
    Thank you
  • guitar9199
    • Sep 2016
    • 1100
    Re: Config wifi SG3110SFNw
    Here's the guide for Network setup.... Go back over the steps you did, and see if you might have missed one.
    • aguatepe
      • Jul 2015
      • 28
      http://support.ricoh.com/bb_v1oi/pub...5/J0306645.pdf
      Thanks for the link. I think I followed those steps, I would have to try WPS ... but I am not convinced works fine.
      My question is, should this device be compatible with WPA2?
      Thanks !
      • guitar9199
        • Sep 2016
        • 1100
        Thanks !
        Page 14.
        1. Enter the network name of the access point.
        2. Select [WPA-PSK].
        3. Select [WPA(TKIP)], [WPA(AES)],or [WPA2(AES)].
        4. Select [Passphrase] or [Hex].
        5. Enter the password for the access point.
        6. Click [OK].
        • Dan G
          • Nov 2014
          • 56
          Thanks !
          yes, and as I recall needs to be done in the WIM? ONLY
          • aguatepe
            • Jul 2015
            • 28
            It can also be done from the machine
              • 37490
              Thanks !
              If you read the entire document you would not be asking that question. The first section is for WPS. The remainder is for configuring the various types of WPA.
