SC545
  • antoney suresh das
    • May 2011
    • 103
    [Error Code] SC545
    Hi Guys,
    Hope everyone is having a great weekend. I need some help with my Ricoh MP 1107 It threw up an error SC545 i checked the entire fixing wiring there was a loose connection which i corrected after which i wanted to clear the error by entering service mode i'm not able to acess the service mode . is there any other way i can clear the error ??Please help . Subsequently I replaced the controller with another one the machine works flawlessly please throw light on how to fix the defective controller. thanks
  • HitMan
    • Aug 2015
    • 170
    Re: SC545
    What combination to enter service did you try?
    Sent from my SM-G930F using Tapatalk
      • May 2011
      • 103
      Re: SC545
      The regular clear 107 cancel press and hold
      • HitMan
        • Aug 2015
        • 170
        Re: SC545
        There is a service mode lock in user tools which might need to be turned off. I think its in the last tab on the bottom page in system settings. Or try instead of 107 806182
        • HitMan
          • Aug 2015
          • 170
          Re: SC545
          Sounds a bit of a long winded process just to clear an sc code replacing the controller. [emoji23] These posts do make me laugh
          • Gab
            • Aug 2015
            • 671
            Re: SC545
            Originally posted by antoney suresh das
            Hi Guys,
            Perhaps one key doesn't pressed ok. Usually isthe no 1 key. Try to press it at different spot of key.
