Ricoh MP 2851
  • darkravenz
    • Oct 2019
    • 3
    [Error Code] Ricoh MP 2851
    Hi, im new here, my problem Ricoh printer show many error code such as SC860, SC870, SC872, SC925 this problem occur after i set printing and scanning . and the major problem is number 7 button on printing device isnt work.. so i can't enter SP code 107, my printer connect using switcher Dlink
    Last edited by darkravenz; 10-24-2019, 11:01 AM. Reason: explain how to connect printer
  • 8T2
    • Aug 2015
    • 257
    Re: Ricoh MP 2851
    Are you using the correct driver and is the cable good?
    Clear print queue and install correct driver if you're not using the correct driver.
    If you can't get into service mode to format HDD you can always use a PC but that would mean a full format and users would need to be programmed again.
    Sent from my WAS-LX1 using Tapatalk
    • davel
      • Oct 2011
      • 1108
      Re: Ricoh MP 2851
      Replace op panel, or repair it, replace HDD.
      • davel
        • Oct 2011
        • 1108
        Re: Ricoh MP 2851
        This information should not be in a public forum.
        Seriously a 2851 with dud panel and HDD, scrap it and use it for parts.
