Ricoh MP 2501L
  • Pulsara
    Technical Manager
    • Aug 2015
    • 27
    Ricoh MP 2501L
    Hi friends I have MP2501L copier with network connection. Unlike MP2501SP copier it doesn't have full detailed web image monitor & I can only enter IP address. also cannot setup to smb scanning & only working with usb scanning. my customer wants to use this as a network scanner. In Ricoh site also they don't issue network twain driver for this model. any advice please. many thanks in advance..
    Re: Ricoh MP 2501L
    what version server / work stations?
    MicroCrap is blocking SMB1 and some copiers don't work on SMB2-3
    Effects of disabling SMBv1: Multifunction Printers and Laser Printers | Products & Services | Global | Ricoh
    • FrohnB
      • Jul 2017
      • 1919
      Re: Ricoh MP 2501L
      Is the ethernet port enabled in service mode? SP5-985 - switch to 1.
      It says the NIC port is an option, and the USB 2.0 is standard, so if it was installed and not enabled in SP mode, then you will have symptoms like you're saying.
      Omertà
        • 37556
        Re: Ricoh MP 2501L
        The network type jack does not guarantee that a model has full network function. The SP in the MP 2501SP stand for Scanner/Printer. The L indicates a Limited or basic machine. You will most like need to add the Scanner/Printer option. Check the Product Support Guide for the order code.
        • sandmanmac
          • 3983
          Re: Ricoh MP 2501L
          You are correct Tim.
          It's not a model that's sold in this part of the world, so I just did 3 minutes of google research myself - which is apparently more than the poster was prepared to do for himself prior to providing the machine to his 'customer' with the promise of SMB scanning
          Only twain scanning is standard. Options are required for SMB scanning - likely the SD card, HDD, etc... but that will be for him to figure out
            Re: Ricoh MP 2501L
            Tim (Slim) knocks it outta the park constantly...
            awesome Guy.. love to split a pitcher with him if I ever get to the left coast again ( unlikely Tim )
            not the guy Sir.. just the loonies in your state.. been there twice.. kissed the marble floors at RDU (Raleigh) when I got back! Don't know how you do it!
            • Pulsara
              Technical Manager
              • Aug 2015
              • 27
              Re: Ricoh MP 2501L
              You are correct I think. this machine doesn't have anything like HDD,SD card. only a simple card with network port fitted to the MB. only facility it has network printing & USB print/scan.
                • 37556
                Re: Ricoh MP 2501L
                You might feel more comfortable here in Bakersfield. We're one of the few conservative holdouts in California. My Congressman is Minority Leader Kevin McCarthy.
                • Pulsara
                  Technical Manager
                  • Aug 2015
                  • 27
                  Re: Ricoh MP 2501L
                  this network still allowed SMB1. other copiers like MP2501SP, MP 3350 working perfectly with SMB scanning in this network. I think this is a basic macine with only network printing. no SD card HDD anything as Sandy explained. Thank you !
                  • Pulsara
                    Technical Manager
                    • Aug 2015
                    • 27
                    Re: Ricoh MP 2501L
                    There's no SP number like 5-985. but MP 2501SP has. I can do network printing. I think port is already enabled. seems no facility for SMB scaning.
                    • davel
                      • Oct 2011
                      • 1107
                      Re: Ricoh MP 2501L
                      Have you printed to it through network port? I bet it does not work.
                      • keithxxiii
                        Just a tech
                        • Nov 2014
                        • 471
                        Re: Ricoh MP 2501L
                        Hi,
                        Since this is a base model, you are limited to scan using twain only. The last time we had this machine when Windows 10 was newly introduced and most of our customers are using windows 7 only. We were able to configure network twain scanning by using this driver.
                        Hope this helps.
                        Aye! Cut the crap
                          • 37556
                          Re: Ricoh MP 2501L
                          Originally posted by keithxxiii
                          Hi,
                          Actually you can also use WIA through the USB port. Just click on Scanner Driver here:
                          MP 2001L/2501L Downloads | Ricoh Global
                          • JayPaul
                            • Oct 2012
                            • 305
                            Re: Ricoh MP 2501L
                            Is this like the old MP 161LN models?
                            I know on there you have to setup lpr printing port in the driver and use lp as the name... been about 7 years since I did this so I'm struggling to remember
