FTP not working
  • JayPaul
    • Oct 2012
    • 305
    FTP not working
    Hi all, I have always been a Scan to Folder guy. Never used FTP in my life and never had to. Until now...
    I have 1 customer, their IT guys refuse scan to folder and setup all their clients with FTP instead. With a tiny bit of help from me a few months ago they setup FTP scan folder and tested it, it worked on MPC 2004.
    They never actually used it though because they also had scan to email, but now they have updated their in house software they want to use the FTP instead and suddenly it doesn't work. I don't know anything about FTP so I updated the firmware just in case which obviously made no difference. Both me and their IT guys have checked the username, password, server name and port are all correct. It can successfully do a connection test on the copier itself to the server.
    As soon as you scan though it just goes to 'standby' and does not send. They are adamant it is the Ricohs fault. I think it is something on the server blocking it. If I connect my PC to that server I can send files to it no problem, but when I setup an IMC 2500 in my office, it does the same thing as the customers machine. Connects fine but won't send.
    Is there anything on a Ricoh that could stop it from working? Everyone seems to swear by FTP that it works all the time but the one time I need it, it doesn't.
    All IP address, subnet, gateway, domain and dns are all correct also.
    Any help will be appreciated
  • copyaction
    • Oct 2007
    • 991
    Re: FTP not working
    What about the folder itself that you are trying to scan to?
    perhaps it is no longer shared or has some other issue, try creating a new shared folder and test with that.
      • 30257
      Re: FTP not working
      Some MS updates remove it from the firewall have there IT check it.
      • JayPaul
        • Oct 2012
        • 305
        Re: FTP not working
        I also just setup my Office PC as FTP Server, so I have control over everything and I know every detail is correct and everything is shared fully. Same thing again, it connects ok but can't send to it. Yet I can browse to the folder/files using Firefox without any problems. Not only is it accepted in Windows firewall, I turned the whole firewall off so there is nothing preventing it.
          • 30257
          Re: FTP not working
          Sharing is not required for it to work. What ftp program are you using? I use filezilla server as its free and easy setup
          • JayPaul
            • Oct 2012
            • 305
            Re: FTP not working
            Ok so further progression now...
            I am using my PC with the IIS enabled... actually got it working. The IMC 2500 cannot scan to it, BUT I also just setup an old MPC 4501 exactly the same and it can scan to it!
            I then setup that MPC 4501 to scan to the customer I am having trouble with... it scanned to that as well.
            So between the 2 machines there must be a setting on the newer one that is stopping it, just need to figure out what?
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Re: FTP not working
              Somebody asked if you're using Filezilla or not?
              I use it all the time and have a step by step install guide that is bullet proof.
              • JayPaul
                • Oct 2012
                • 305
                Re: FTP not working
                I used IIS for FTP on my office PC and for the customer going to their server I used filezilla client to check and see if files were going through.
                What I found in the end is, from both copiers I can scan to both my FTP server and the customers server but only directly to it, if I try directing it to an actual folder it just won't send. I even made a new account and gave it every permission under the sun to a scan folder but as soon as you try scanning it it goes to 'standby' in the scan file status.
                I can't figure out why it can scan to 192.168.1.200 (for example) but if you put any path like /Scans or \Scans (tried both just in case) it cannot send.
                I can't see any setting I have missed in the 2 guides I have seen for FTP scanning now
                EDIT - I just noticed on that guide actually the path is just the name of the folder without / or \ before it... i'll try that tomorrow
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  Re: FTP not working
                  We usually just run the Filezilla server on the customer pc...we don't bother with the client.
                  • BaconSteve
                    • Apr 2019
                    • 140
                    Re: FTP not working
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      Re: FTP not working
                      Time to putty up mah chinks
                      • JayPaul
                        • Oct 2012
                        • 305
                        Re: FTP not working
                        I'll tell you what... that guide helped me in the end, from my last edited post I said I would set the path to the folder without \ or / before it... it worked!
                        I noticed as well the folder name was Docs and in the path it has to be written exactly like that with the capital D not lowercase. This is my first experience ever with FTP so I was never going to know that but thankfully I do now... not that i'll ever be using FTP again but still.
                        Thanks for the help guys
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          Re: FTP not working
                          I tend to use Scan to FTP for Kyocera...they can be flakey sometimes on SMB scanning and I'll use FTP as a last resort.
                          • JayPaul
                            • Oct 2012
                            • 305
                            Re: FTP not working
                            My dance of joy and smug swagger waqs cut very short as I remoted into my customers network earlier, adjusted the path, got them to send a scan and it didn't come through!! I still had 2 copiers in my office set up to it and they both worked still. Exactly the same port, credentials, server and path. So that sucks!
                            Not only that but the customer then said within that folder are about 12 more folders, 1 for each individual user. I have no idea how to get to them so for example the server is 192.168.1.200 then the Path is Docs
                            So say the next folder is called Test does it go 192.168.1.200 - Path is Docs\Test ? Because I tried with \ then also / . : just to see if those 3 worked all to no avail. In SMB it is just Docs\Test, the backslash lets you go to next level as many times as you want to get to its final destination (good film but off topic)
                            • BaconSteve
                              • Apr 2019
                              • 140
