Ricoh mp55oo feed unit
  • mikadonovan
    • May 2008
    • 2931
    Will a Ricoh MP 5500(B246) paper feed unit work in a Ricoh 2051(B140)? I would like to replace a 2051 feed unit, but the parts list I have for this model does not have a number for the whole unit. My MP 5500 parts list does, and they appear to be the same. Somebody may save me the trouble of actually swapping the units to find out.
    NEVER ASSUME ANYTHING
  • FRIDGEMAGNET
    • Aug 2007
    • 377
    B140 6200 Paper Feed Unit Ass'y (Model C2)
    • mikadonovan
      • May 2008
      • 2931
      Thanks for the reply. What exactly is a C2 model?
      • Captain Scott
        • Dec 2008
        • 166
        Is it a LCT or Doc feeder you want to swop over?
        MP 5500 info.
        Large Capacity Tray RT43. Product code 411183
        4,000 sheet capacity
        AF 2051 info.
        Large Capacity Tray RT43 Produst code 411183
        4,000 sheet capacity.
        Above info is from the product guides, so you can use the LCT on the 2051.
        • FRIDGEMAGNET
          • Aug 2007
          • 377
          Hi
          The 2051 is the Martini C2
          The MP 5500 is the Martini C3
          • mikadonovan
            • May 2008
            • 2931
            Originally posted by Captain Scott
            MP 5500 info.
            AF 2051 info.
            The base engine paper feed unit. There are 3.
            • mikadonovan
              • May 2008
              • 2931
              Originally posted by FRIDGEMAGNET
              Hi
              That must be a European designator. I've been a U.S. tech for 20 years and have never heard of that. Thank you much for the help.
              • KopyKat
                Nurse Ratched of Repair
                • Nov 2008
                • 365
                It's the R&D code name from Japan. There were series of planets and flowers too. The 1224 was Model U for Uranus.
                sigpic
                Relax! This firmware injection won't hurt...but it will take 45 minutes.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  They were even named after cocktails at one point.
                  Bellini
                  Mojito
                  Martini
                  Russian
                  etc.
                  I love the Uranus one, they are a total ARSE to work on.
                  These are the design names Ricoh use for the various breeds of copier and are used across all brands / countries. You might just know them by their individual model number, i.e. Russian C2 is a 1027 in Ricoh speak, a 5627 in Lanier speak, 2712 in Gestetner.
                  Hit it.
                  • Rami Ayoub
                    Yes you can replace the paper feed unit between 5500 and 2051!!
                    • mikadonovan
                      • May 2008
                      • 2931
                      Thanks all for the good information.
                      • Jomama46
                        • 2900
                        Very appropriate!
                        sigpic
                        A+; Network +; PDI+
                        • Shadow1
                          • Sep 2008
                          • 1642
                          Ricoh has annoyed us with the name/model/development name for years: the Aficio 1224 was also the C2408, DSc224, LD024c, B051, and Uranus-C1a
                          Same thing for the finishers, and any given document will randomly select a name for the machine. This drives me nuts - The product code can be useful when ordering parts, and I can understand the different companies having different names, but why do we ever need the development name?
                          I'm a Legacy Lanier tech, So I'm biased toward the Lanier Model numbers - I can look at LD024c and know it's a Digital (LD) First generation (0) 24PPM Black and White (24) Color (c at the end or LC prefix, but then the speed would be for color mode making this an LC006) BTW the LD124c was just as bad, but I only know that from the one we inherited we knew better than to sell any.
                          73 DE W5SSJ
                          • FRIDGEMAGNET
                            • Aug 2007
                            • 377
                            Over here we can be working on Nashua, Rex Rotary, lanier Gestetner or Ricoh all with different model numbers for the same model so I prefer the design name.
