Ricoh NFC counter read
  • sbalika1983
    • Oct 2019
    • 3
    Hi everyone!
    We have a lot of Ricoh MPC2004 and other android based machines. I was wondering, that is there any way to read out the total conter from this machines quickly through NFC with an NFC ready smartphone? If yes, how can I set up this to work?
    Thanks.
    Balazs.
    • 36995
    Re: Ricoh NFC counter read
    First, the MP C2004 itself is not an android based machine, only the Smart Operation Panel.
    As originally implemented on the SOP, NFC was used to provide connection information, IP address, to Ricoh apps running on another android device. You can setup an icon on the SOP that will email the counter, might require addint the SendMeter app first. Also using the Smart Operation Designer software to install the SendMeter app that will automatic email the counter on a specific date of the month.
    • COPIERMAN
      • Jun 2009
      • 559
      Email counter report from copier
      Setup File Transfer/ Setup smtp email server and password if needed also enter a email administrator and turn on auto specify sender name to on
      7. Go to service mode
      8. 5-866-110 set to 1
      9. 5-866-114 set to 1 this one sets day to send
      10. 5-866-115 set to 1 this one set time to send
      11. 5-866-121/122/123 Enter email where to send counter report can do up to three emails.
      12. Turn off copier and turn back on then try 5-866-112 should say complete.
