Mp7500 replace new developer 2801 initialize after that overtoning
  • hsh6049
    • Jul 2012
    • 64
    mp7500 replace new developer 2801 initialize after that print out overtoning check everything fine ...finally 5801 all memory clear
    and found out the 7 digits inside the 2801 erase so my question do i need initialize 2801 again & key in the 7 digits again
    thanks a lot
  • Codex
    • May 2008
    • 694
    Re: Mp7500 replace new developer 2801 initialize after that overtoning
    thanks a lot
    Why doing a Memory clear after changing developer???
    Normally if you enter again 2801 you can digit again and press "#" . It's not a "one time value".... You can digit again and again.
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
    • hsh6049
      • Jul 2012
      • 64
      Originally posted by codex
      why doing a memory clear after changing developer???
      Inviato dal mio sm-g935f utilizzando tapatalk
      i been try whatever i can the dv tank full of toner unplug the toner end sensor running about more than 1000 copies and back to normal but sp2223 reading 11v and also check dv motor everything find
      still cannot solve
      • davel
        • Oct 2011
        • 1094
        You have bricked machine with memory clear, change dev again and any other parts that are due, input factory data from birth certificate then initialise dev. Good luck.
        NEVER CLEAR ALL MEMORY!
        • wilez
          • Jan 2011
          • 54
          That model was known to have mag brush ground and drum ground issues on high meters. Also if using aftermarket drums and toner will cause overtoning. as mentioned above start from scratch if possile.
          Make sure mag brush is contacting ground in rear, do new developer, drum, wires and grid then go through your adjustments.
          FYI! had to replace mag brush a couple of times to stop overtoning.
          https://t.me/pump_upp
            • 37319
            As for your question concerning the lot number for the developer being cleared, no big gig. It is merely the batch number of the developer and is stored for the record keeping purpose. Should Ricoh discovers a contaminated batch of developer, they will send out bulletin. You can then check the batch number on all your machines.
            As to running SP 5801-001, you have cleared ALL the factory settings from memory.
            • hsh6049
              • Jul 2012
              • 64
              wht should i do next? ....now dvtank inside full of toner can i initialize 2801 again
                • 37319
                NO!!! Just keep a record of the lot number. If you really want to initialize the development unit again, use another new bag of developer.
