Ricoh color test pattern not aligned
  • Dick78
    • Aug 2015
    • 21
    [Misc] Ricoh color test pattern not aligned
    Picture-2019.jpgHi All,
    Can someone help ! As you can see in the attached file, The color pattern printed is not aligned.
    Can you please direct me to fix this issue ?
    Ricoh MPC 3000
    Regards
    Dick78
  • wcanonw
    • Aug 2014
    • 404
    Re: Ricoh color test pattern not aligned
    Originally posted by Dick78
    Hi All,
    Regards
    Dick78
    hello good morning you have to specify well what the Ricoh printer model is and send photos of the problem.
    If it is a problem of color registration, it is probably one due to a transfer belt unit problem, but you need to send images of the problem
    • FrohnB
      • Jul 2017
      • 1919
      Hi All,
      Regards
      Dick78
      There is no picture attached. What model are you working on?
      Omertà
      • Dick78
        • Aug 2015
        • 21
        please find the picture attached. The modele is Ricoh MPC 3000
        Thank's
        • vicalvarez
          • Mar 2014
          • 33
          [ATTACH=CONFIG]44034[/ATTACH]Hi All,
          Ricoh MPC 3000
          Regards
          Dick78
          Enviado desde mi iPhone utilizando Tapatalk
            • 37515
            If you are an end user try running Auto Color Alignment in User Tools - Maintenance. If ACA in User Tools or Auto Line Position in SP ends in an error and does not alignment or the problems returns, the ID sensor assembly is dirty. Clean it with a cotton cloth moistened with water.
            • FrohnB
              • Jul 2017
              • 1919
              Like Slim said, Try Auto Color Calibration. "User Tools/counter" --> "Maintenance" --> "Color Registration".
              If that doesn't get you straightened out, then go into SP mode and execute SP 2-111 mode C first, then mode A after that. (Mode C = rough adjustment, Mode A = Fine adjustment twice).
              If that doesn't get you aligned, then you will probably have to clean the ID sensors. You could also do this step First.
              Omertà
              • Dick78
                • Aug 2015
                • 21
                Originally posted by vicalvarez
                <i
                Thank you for you reply. I will try try it this week-end.
                Regards
                Dick78
                • Dick78
                  • Aug 2015
                  • 21
                  Thank's. I will try it.
                  Regards
                    • 37515
                    Like Slim said, Try Auto Color Calibration. "User Tools/counter" --> "Maintenance" --> "Color Calibration" (do this for copier and printer, there are 5 different ones to do I believe).
                    Not color calibration, that is for image density. Color registration, User Tools version of SP 2111. Does both rough and fine automatically.
                    • FrohnB
                      • Jul 2017
                      • 1919
                      You are correct slim. Should be "Color Registration".
                      Omertà
