mpc3002 double sided wrinkles
  • mgofimat
    • Feb 2014
    • 5
    Hello:
    I am going to open a new case since you have told me that the previous one was very old.
    I have always had problems with several teams in this series.
    Sometimes it has been the comb of the transfer roller, other times it has been the film, in that case I have always changed film plus depression roller
    I have no problem with one face.
    But double-sided in printer mode and when the equipment wants it forms a wrinkle, a symptom similar to swollen pressure rollers in a range of old equipment, in copier mode I have never seen it but I cannot assure it does not come out.
    I have exchanged fixing units and the equipment that goes wrong continues to fail, while the one that goes well does not give problems, I have taken paper from one place to another, transfer sets, bands and always with the same result.
    I have seen newsletters that talked about increasing the speed of fixation that I have also done but I do not find the problem.
    I have also tried to run the device with drivers of another model and nothing has been fixed
    The last thing has been, a team that has never failed me and has always worked double-sided, I took it to a client whose machine has given problems, because the first impression that is done on both sides goes and removes the wrinkle.
    I think it has to do with the combination of humidity and temperature in the place where the equipment is installed.
    Some of you would know if I can vary the temperature and humidity values.
    Thanks in advance.
    Re: mpc3002 double sided wrinkles
    Originally posted by mgofimat
    Hello:
    Thanks in advance.
    long diatribe with NO substantial info.
    print SMC report and config post it here
    what size type paper
    problems from one or all paper trays...
    life on consumables and service parts
    humidity put a de-humidifier next to copier
    what are the conditions of the environment ?
    what type paper
    what driver?
    what error codes?
    picture of the jam?
    so many Q's so little info.
    • mgofimat
      • Feb 2014
      • 5
      sorry
      you can see the firmware is updated to the latest versions,
      The problem occurs in all paper trays and normal 80gr paper is used.
      The film and the pressure roller controlled 10,000 pages
      The team will have 60,000 b & w pages and 10,000 color pages
      Clean laser and band too
      The client's role took me to another machine and it doesn't give problems
      You have already indicated that a team from another customer and that has never failed to take this customer to the first has failed.
      201911181758.pdf
        sorry
        [ATTACH]44074[/ATTACH]
        what is this "team" you keep referring to?
        your terminology is hard to define
        did you rebuild fuser?
        is there build-up on fuser inlet guide?
        " client's role took me to another" WTF are you trying to say?
        does it do it on simplex runs?
        have you cleaned/replaced duplex section?
        are you a newbie tech?
        lines/wrinkles/jams are 'Copier Tech 101' issues.
          • 37483
          Since you think that the problem might have to do with humidity, have you tried installing the Anti-Condensation Heaters Type A? This option is provided as a service part.
          • mgofimat
            • Feb 2014
            • 5
            I am not a novice technician, I have 30 years of experience in Ricoh, but it is true that I have not had access to the courses for 10 years.
            although I do have access to the manuals.
            For me, the problem has to do with environmental conditions.
            I have not put any heater since as I said a mpc2051 works well and that is next to the mpc3002
            I am currently playing with sp2302-2 to see if there is any improvement.
              • 37483
              Have you examined the copies to determine if the wrinkling occurs before or after the PTR? You may have a warped exit guide on the duplex unit.
              • K-3
                service technician
                • Feb 2018
                • 51
                from the look of your sample i would rule out the fuser as the wording in the crease looks fine or does the toner rub off in the wrinkle
                  • 37483
                  sorry
                  This looks to me like the front side that as you have said there is not a problem with single sided. Can you send images of both sides of the crease?
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    It's an MPC 3002...check the transfer case.
                    • MIGUELMARCHENA
                      • Feb 2018
                      • 192
                      It has happened to me in several cases, including those exposed
                      I WILL PUT OTHERS
                      1) Deviated transfer case
                      2) Feed foot improperly installed and the respective transport guide
                      3) poorly accommodated duplex
                      4) unevenly worn separation rubbers creating a vacuum in the sheet, which when passing through the fuser, sometimes the grain comes out, but more often when duplexing
                      5) uneven registration due to breakage of roller bushing
                      • duct tape
                        • Jun 2009
                        • 87
                        • MIGUELMARCHENA
                          • Feb 2018
                          • 192
                          Hi good dayCould you please put a picture of the problem?thank you very muchCheers
                          • mgofimat
                            • Feb 2014
                            • 5
                            Hi:
                            I am sorry for the delay but I needed to do some tests to be able to give the result.
                            Most of the things that you comment on, I know him and I knew that he could produce the wrinkles, but in this case it was reviewed and as I said the main problem is that a machine that had never failed and knew that it worked well takes it to the client, and the First copy he made double-sided was with the wrinkle.
                            This made me think that it had to do with the environment where the MPC3002 was.
                            Checking the SP I found the 2-302-2 and put it in 3 to treat the environment as normal, almost two weeks ago and I had no more problems
                            I understand that if the machine modified the transfer values along with some paper curvature, the paper did not fit well into the fuser.
                            I say it because to one side never, it has never gone wrong and as you can see in the images that the transfer sent to the paper is correct as well as the alignment on the page.
