Savin 2400WD Windows 10 Driver
  • bernard_s3
    We have an older Savin 2400WD that needs repair and we are trying to find out if there is an updated driver to allow it to work with Windows 10 to see if it is work getting repaired. Unfortunantly our dealer went out of business and I cannot find much online. Any help would be appreciated.
    Re: Savin 2400WD Windows 10 Driver
    try doing a search of Ricoh/Savin windows 10
    what doesn't work?
    Print Scan Copy?
    if scan on a Enet network.. you might have an SMB issue (also covered ad nauseam here) which is firmware replated.
    Printing what driver are you using now? (please NO WSD)
    you didn't really give enough info for us to help you.
    what type of repairs needed?
    PhilB. "The Dentist"
    • mikadonovan
      • May 2008
      • 2931
      Go to Ricoh-Usa and search for the MP W2400 driver. It's on there , I just checked.
      NEVER ASSUME ANYTHING
      • Dan G
        • Nov 2014
        • 56
        Windows 8 will work as well
        • eccelobo
          • 113
          I always install printers in Windows 10 with driver for windows 7 64 bits and never had a problem.
          • Brianneoe
            • May 2015
            • 322
            The Savin 2400 only worked with a external Ratio controller. It is based on the old Windows XP or 2000 OS. I take it that you know this and you are looking for the upgrade controller unit. PM me and I will provide you with Ratio USA contact. His name is Rick Hipsky and he is out of Miami FLA. They have both WIN7 and 10 upgrades for the controller. The last time I upgraded one it cost me about $1800USD. You will need the license number on the old card.
              • 37620
              The newest driver version, 6.0.0, for that model was released 09/02/2015.
