Ricoh MP 9002 folding corners when duplexing
  • copierjeff
    • Jun 2015
    • 21
    Fuser has been rebuilt not to long ago. I replaced the duplex solenoid and feed gate at entrance to the duplex tray.
    It worked fine for a while and now it's bending the corners again. Not every time, but pretty much.
    • 36856
    Re: Ricoh MP 9002 folding corners when duplexing
    Check the plastic rib on the lower transport guide plate of the duplex unit where that corner of the paper rides going through. I have seen the paper wear a notch in the rib and either cause bent corners or jamming. You can usually smooth it with sand paper.
