Ricoh MP C4503 wireless LAN
  • wester
    • Aug 2009
    • 113
    Can someone tell me if the wireless LAN option code 416572 and code 417493 are the same? My customer has a MP C4503 and they want or would like wireless connection. Maybe a recommendation of an aftermarket.
  • illude2
    • 30
    Re: Ricoh MP C4503 wireless LAN
    417493 is a type M19 For use with: Ricoh SP 8400DN, C840DN, C842DN printers
    416572 is a type M2 for the MPC2003-6003
    The are not the same from any documentation i can find.
    • sandmanmac
      • 3990
      Use a wireless range extender. I've never used anything but one of these, when required.
      A fraction of the price. 5 minute configuration, and probably more reliable - at least from what I've read.
        • 37628
        As Sandy said, the Ricoh WiFi interface is grossly over priced. It is also a pain to install and configure.
        You can find dual channel WiFi range extenders online every where. Most merely plug into an AC outlet and have a CAT 5 jack for connecting a wired device. I have even used them to connect small work groups by connecting a 5 port switch to the CAT 5 jack. Most are under $50.00
        • keithxxiii
          Just a tech
          • Nov 2014
          • 471
          And I never had close to 100% signal strength with ricoh wireless adapters. Not even 80%
          Aye! Cut the crap
            • 30550
            Wireless will never be as fast hardwire. Wireless should only be used as last resort, 4503 is a large MFP and would not recommend it. Sometimes customers that it must be wireless so they can used it from phones or wireless connected PC's
            • skinnyb
              • Jul 2008
              • 291
              Truth. The wireless adapters are weak. I use an aftermarket wireless gaming bridge usually, I believe the one I normally use is made by TP Link and it's less than $50 and easy to configure. By the time the customer orders it and pays my labor to come and setup its MUCH cheaper and more reliable than the official Ricoh wireless card.
              Sent from my LM-V405 using Tapatalk
              • mikadonovan
                • May 2008
                • 2931
                I used one of these in a warehouse full of metal shelving 75 ft from the router, and there were never any connection issues.
                NEVER ASSUME ANYTHING
