Ricoh mp 9003 toner hopper leaking toner
  • eccelobo
    • 113
    Re: Ricoh mp 9003 toner hopper leaking toner
    Originally posted by n25an
    ok...
    D1313161 -- sits untop of the developer unit
    A2293266 -- upper shutter shield on toner hopper
    A2293263 -- lower shutter shield on toner hopper
    A2933234 -- shield plate that sits behind spring loaded part of toner hopper
    A293 3227 -- toner slider... I guess when it sticks it creates an openning for toner to get through...
    ok... sounds like you are covering all the bases...
    how often have you replaced these parts and how long does the fix last...???
    I always carry all the set, and see what is needed to replace. -3227 and -3234 are the most wear out, -3266 also is often disintegrated, -3161: check the seal and -3263 is almost never replaced.
    All this for the toner spilling issue. If there is developer leaking there are other parts involved.
    Good luck!
    • n25an
      • 1030
      With the Martini models, if force toning brings the image back, you might have a dirty ID sensor. These models are known for dropping toner from the cleaning station. If cleaning corrects the problem but it comes back in a week or so, replace the cleaning brush and cleaning entrance seal.
      ok...
      will do...
      and thanks again...
      Sad To Say I Don't Have a Life
      I do this stuff on the weekends too
      • n25an
        • 1030
        Good luck!
        thanks for the info... now i know where to start from...
        • fuwei2422
          • Nov 2014
          • 49
          #19
          replace pairt is good 密封胶圈 ,即可 fuwei2422@163.com
